Mass flow through a patch
Like Tree1Likes
  • 1 Post By alf12
Old   October 4, 2010, 11:00
Default Mass flow through a patch
alf12 is on a distinguished road
I want to calculate mass flow through a patch, using incompressible RANS transient solver (2D case).
I have tried various methods, but I have some trouble with all of them
1 - Using post processing tool patchIngrate
patchIntegrate phi outlet
It works, but I have to format the file as an array to post process it and that's time consuming. I have done it for a few cases and I need a more efficient solution.
2 - Using libsimpleFunctionObjects library
2.1 - "patchMassFlow" function :
In this case I have a strange warning from OpenFoam :
--> FOAM Warning :
    From function SolverInfo::SolverInfo(const dictionary& dict,const objectRegistry &obr)
    in file SolverInfo/SolverInfo.C at line 88
    Neither LES nor RANS found. Assuming no turbulence
2.2 - "patchIntegrate" function with field U
It works but the output is a vector and once again I have to process the file before I can use it.
Actually the best solution should be using patchMassFlow but I struggle to understand this warning.
Thanks for help
mm.abdollahzadeh likes this.
alf12 is offline   Reply With Quote
Old   October 4, 2010, 11:05
Emanuele
nuovodna is on a distinguished road
Take a look here:
http://www.cfd-online.com/Forums/ope...-openfoam.html
I attached a file of calcMassFlow that works on OF 1.7+
nuovodna is offline   Reply With Quote
Old   October 4, 2010, 11:44
Thanks for your answer. No problem to run your code but actually I have the same problem than with patchIntegrate, ie I have to format the file. I would like to get something that I could read more or less directly with gnuplot.
#Time Massflow
0.02 12.51
0.04 13.20
0.06 15.24
Anyway I will try to change the output format either in your code or either in the patchIntegrate tool.
Old   October 4, 2010, 12:02
Emanuele
A precision: it's not my code. I only made some modification to get it working on OF 1.7.x
Original source code:
http://openfoamwiki.net/index.php/Contrib_calcMassFlow
I hope you can modify the code and obtain a "gnuplot ready" file
Regards
Emanuele
Old   October 5, 2010, 03:33
So, I have made change in the patchIntegrate tool to fit my need and basically it works.
Anyway, I would prefer to use the libsimpleFunctionObjects in order to control the output interval and I don't really understand if the warning I get is a bug or if I miss anything.
I get this warning only when I use the patchMassFlow type with this lib and not when using the patchIntegrate type from the same lib.
Old   October 5, 2010, 12:49
Assistant Moderator
Bernhard Gschaider
Originally Posted by alf12 View Post
--> FOAM Warning :
Thanks for help
Don't mind the warning. The SolverInfo-class just tries to determine the properties of the solver you're working with and fails to understand new-school turbulence. But to calculate the massFlow you don't need turbulence so you'll be fine
Bernhard
PS: bug-Report at the mantis of the extend-project would be nice though
Old   October 6, 2010, 04:47
Bernhard, thanks for your answer.
I am still in the learning process with OpenFOAM and I have thought that SolverInfo was an OpenFOAM class.
I have run a calculation using patchMassFlow from libsimpleFunctionObjects and so far everything looks fine.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
[blockMesh] Cyclic BC's: Possible face ordering problem? (Channel flow) sega OpenFOAM Meshing & Mesh Conversion 3 September 28, 2010 12:46
different mass flow rates michael FLUENT 4 February 21, 2005 03:48
Target mass flow rate Saturn FLUENT 0 December 10, 2004 04:18
