‘patchi’ was not declared in this scope
Old   June 26, 2011, 05:02
Default ‘patchi’ was not declared in this scope
doubtsincfd is on a distinguished road
I am trying to write gradT on a wall in laplacianFoam as follows (code addition in write.H file)
volScalarField surfGradT
IOobject
"surfGradT",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::AUTO_WRITE
gradT.boundaryField()[patchi].snGrad()
on running wmake I am getting the error‘patchi’ was not declared in this scope. How can I resolve this error?
doubtsincfd is offline   Reply With Quote
Old   June 26, 2011, 05:12
I am using OF 1.7
Old   June 26, 2011, 05:23
Retired Super Moderator
Bruno Santos
Greetings doubtsincfd,
Where did get that code from? The variable patchi is clearly to be used for iterating over all patches...
So, if you check where the variable is defined and used, prior to the code from where you copied it from, you should be able to adapt to your code!
Best regards,
Bruno
Old   June 26, 2011, 05:29
Thank you, Bruno
I am trying to build a code based on the code for gradTx given in solvers/basic/laplacianFoam/write.H. I want to calculate normal gradient of T on the patches. I am not so familiar with code modification of OF, so it is quite likely that I am making a basic mistake.
I am trying to define "surfGradT" variable in the same way gradTx has been defined. Why is the code not recognizing patchi?
Old   June 26, 2011, 05:36
Bruno Santos
OK, I've just looked at the file... So, where did you get this from:
Old   June 26, 2011, 05:41
I got it from the file
applications/utilities/postProcessing/wall/wallGradU
The formula which I referred from the file is:
wallGradU.boundaryField()[patchi] = -U.boundaryField()patchi].snGrad();
Old   June 26, 2011, 06:11
Bruno Santos
You dropped a crucial line:
forAll(wallGradU.boundaryField(), patchi)
        -U.boundaryField()[patchi].snGrad();
The forAll line is the one who iterates over all patches.
My advice to you is this: if you haven't done this before, do this tutorial first: http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam
If you follow that tutorial, you will learn valuable lessons about the OpenFOAM code!
Good luck!
Bruno
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 12:34
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
