Implementation of maxwell slip velocity and Temperature jump with openfoam
Old   November 8, 2010, 11:36
Default Implementation of maxwell slip velocity and Temperature jump with openfoam
m
yassepid is on a distinguished road
I want to Run supersonic flow of air over a cylinder at Knudsen number Kn=.01
And therefore, I must to use Maxwell’s velocity slip and Smoluwski temperature
jump conditions at the wall boundary.
I see these condition in openFoam classes as :
Foam::maxwellSlipUFvPatchVectorField
Foam::smoluchowskiJumpTFvPatchScalarField
i use these boundary as follow:
type maxwellSlipU;
accommodationCoeff .5;
Uwall uniform (0 0 0);
thermalCreep on;
curvature on;
value uniform (0 0 0);
refValue uniform (0 0 0);
valueFraction .5
but i encounter this error
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/aminiyasser/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/aminiyasser/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 in "/lib/libc.so.6"
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/home/aminiyasser/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#4 Foam:perator/(Foam::UList<double> const&, Foam::UList<double> const&) in "/home/aminiyasser/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#5 Foam::smoluchowskiJumpTFvPatchScalarField::updateC oeffs() in "/home/aminiyasser/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/librhoCentralFoam.so"
#6 Foam::mixedFvPatchField<double>::evaluate(Foam::Ps tream::commsTypes) in "/home/aminiyasser/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libfiniteVolume.so"
#7 Foam::mixedInternalEnergyFvPatchScalarField::updat eCoeffs() in "/home/aminiyasser/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libbasicThermophysicalModels.so"
#8 Foam::mixedFvPatchField<double>::evaluate(Foam::Ps tream::commsTypes) in "/home/aminiyasser/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libfiniteVolume.so"
#9 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::evaluate() in "/home/aminiyasser/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64GccDPOpt/rhoCentralFoam"
#11 __libc_start_main in "/lib/libc.so.6"
#12
Floating point exception
for solve this error what i must do ?
yassepid is offline   Reply With Quote
Old   June 10, 2012, 23:46
Default Hi dear foamer
Esmaeil Ahmadiyan
e.ahmadiyan is on a distinguished road
I have same problem as you nowadays Could you help me to implement this boundary conditions ? Thanks a lot in advance. Best regards.
e.ahmadiyan is offline   Reply With Quote
Old   June 28, 2016, 07:05
Quasar_89's Avatar
Suyash Sharma
Quasar_89 is on a distinguished road
I am sure, i have read enough papers on the Kn number to comfortably say that your assumption about slip velocity at Kn < 0.01 is not correct. This is true for an order higher which is Kn approx equal to 0.1.
Quasar_89 is offline   Reply With Quote
How can I implement temperature jump boundary condition in microchannel walls? sima FLUENT 1 December 8, 2010 08:20
velocity and temperature profile vickrenz FLUENT 0 August 30, 2009 23:58
UDF velocity and temperature Raj FLUENT 3 February 1, 2009 18:29
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 02:13
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
