precedence of boundary file over blockMeshDict |
January 28, 2011, 15:23 |
Brian Fiedler
Rep Power: 16 |
In the OpenFoam tutorials, Allclean deletes the following files in constant/polyMesh: "points", "owner", "neighbour", "faces" but not the file "boundary". The blockMesh utility will overwrite "boundary", but will first read "boundary" and preserve that patch type that is found, igonoring what is found in blockMeshDict. Thus, changing type wall to type cyclic in blockMeshDict will have no effect on type found in the "boundary" file. Options to change file type are to manually delete the "boundary" file (better for newbies to save it by renaming it) or to manually edit it. What is the purpose of the blockMesh utility behaving this way? The official documentation http://www.openfoam.com/docs/user/blockMesh.php does not describe this behaviour.
January 22, 2013, 07:16 |
Ehsan
Rep Power: 26 |
hi.i have same question.did you find a ratioanal answer?
January 22, 2013, 10:52 |
Brian Fiedler
Rep Power: 16 |
No, I did not find an answer. I have also forgotten the context of my original post, which was from so many years ago.
blockmesh, bockmeshdict, patch type |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
PHI file structure | Eugene | Phoenics | 9 | November 2, 2001 22:00 |
