surface roughness
Old   February 10, 2011, 11:30
Default surface roughness
isa_ is on a distinguished road
Hello.
I was simulating the behaviour of a water droplet on an inclined surface. Up to now I've been using InterFoam solver, making the assumption of laminar flow. I specified the contact angle in the o/alpha1 script and gave no other parameters. I now need to model a rough surface. I was thinking of going on with InterFoam but using a turbulent model (a standard k-epsilon model). I've read that the surface roughness can be implemented in the o/nut file by using the nutRoughWallFunction. Does this make sense in my case? What else do I need to change in the model if I use a turbulent model?
I tried to lunch a couple of simulations using this model but i ended up with a fatal error after some iterations. The problem is linked to the adjustable Delta T. Could it be linked to an error in the boundary conditions?
Please, any help is really appreciated.
Thanks.
isa_ is offline   Reply With Quote
nutRoughWallFunction and Surface Roughness Documented AlanR OpenFOAM Programming & Development 64 January 6, 2024 07:13
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Surface roughness alefem FLOW-3D 6 June 3, 2010 12:49
