Klaus
Rep Power: 22 ![]() |
I am working on the setup of my wing optimization (lift/drag) case (3D). - Re-range is 300.000 to 1.500.000 - It's a hydrofoil, fluid is water - Medium chord is 100mm, wing span is 1040mm - Simulation domain size is 1000mm x 1600mm x 1000mm (for half the wing span as it's a symmetrical case) - I'll be using simpleFoam + SpalartAllmaras - Using http://geolab.larc.nasa.gov/APPS/YPlus/ I get a ds = 0.0000020m = hight of the first cell row on the wing surface for a desired y+ of 0.5 at Re = 550.000 Question 1: Where can I define such a value for ds using snappyHexMesh? Question 2: Problem with locationInMesh: Can this be just any location inside the domain but outside the wing? Question 3: Any recommendations for the overall mesh to get good results for cl/cd? Klaus |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
[ICEM] how to mesh a sail (and the rest of the boat) | matteoL | ANSYS Meshing & Geometry | 4 | May 7, 2012 10:23 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
basic of mesh refinement | arya | CFX | 4 | June 19, 2007 12:21 |
Mesh | Mignard | FLUENT | 2 | March 22, 2000 05:12 |
