December 29, 2010, 17:41 |
dieselFoam tutorial - OpenFOAM-1.6-ext
Rep Power: 16 |
I tried to run the tutorial aachen bomb with 1.6-ext but it crashes after a while with the error janaf out of temperature range. That s very strange, since I ve run that tut with other OF versions without problems. Can anyone check if you get the same error? Maybe my OpenFOAM-1.6-ext is not properly compiled. Regards Peter |
December 30, 2010, 11:20 |
Nakul
Rep Power: 16 |
Have you made any changes to the tutorial?
If not can you tell what exactly are you doing to run that tut? Are you running the tut provided with OF-1.6.x only? I am not sure why this may be happening but your answers to above questions might make it possible to help you. |
December 30, 2010, 12:18 |
#3 | |
Rep Power: 16 |
I am using OF-1.6-ext and not 1.6-x. I am using the tut provided by 1.6-ext. This is the error which I get after a while. In the beginning it runs but than it crashes. Furthermore, a case which runs with OF 1.5-dev exhibit the same problem.
December 31, 2010, 05:37 |
Nakul
Rep Power: 16 |
That's pretty strange. Usually tutorials run without a hitch. You may try to re-install your OF. Have you tried running other tutorials? If you find a solution to this problem then do post it here. |
December 31, 2010, 06:06 |
Rep Power: 16 |
Indeed it s strange. Other tutorials run without a problem. I checked the source code of the dieselFoam solver. It is modified to the version of 1.5-dev. Maybe a bug?
Can someone of u check if the tut aachenbomb (dieselFoam) provided by 1.6-ext with OF-1.6-ext runs to the end? I ve tested it on two different systems. |
January 10, 2011, 03:11 |
Rickard
Rep Power: 15 |
Did you fix the problem?
Maybe you did change some settings in the injectorproperties? |
January 10, 2011, 12:31 |
Rep Power: 16 |
No. I didn t
Does it work out for you? |
January 11, 2011, 06:32 |
Nakul
Rep Power: 16 |
Hi
I am uploading the aachenbomb tutorial from OF-1.7.1 Try running it with OF-1.6-ext. If you succeed then find out the differences and post them here. |
January 12, 2011, 13:31 |
#9 | |
Rep Power: 16 |
It doesn t tun neither. The only difference is that in sprayProperties this is adjusted
sprayIteration Quote:
March 18, 2011, 11:28 |
#10 |
Fabien DOS SANTOS
Rep Power: 16 |
I have the same problem, the tutorial case doesn't work.
I tried to used some personal cases from 1.7.x, which were okay but they don't work on 1.6-ext too, I get the same error. |
icoFsiFoam on OpenFOAM 1.6 | waku2005 | OpenFOAM | 13 | February 14, 2013 17:27 |
OpenFOAM 1.5 vs. 1.6 vs. 1.7 | skarnani | OpenFOAM | 2 | July 7, 2010 17:46 |
Problem using ParaView/Parafoam in OpenFoam 1.6 | titio | OpenFOAM | 1 | February 7, 2010 18:55 |
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 7 | January 19, 2010 15:39 |
OpenFOAM 1.6 installation in Ubuntu 9.1 | jsm | OpenFOAM Installation | 4 | January 3, 2010 22:53 |
