Phase Change Heat Conduction
Old   April 13, 2011, 10:47
Default Phase Change Heat Conduction
hawkeye321 is an unknown quantity at this point
Hi all
I am a new user of OPEN FOAM and I want to model a "Phase Change Heat Conduction Problem" with it.
Would you please let me know if there is a tutorial for phase change heat conduction simulation with OPEN FOAM? There are some tutorials for OPENFOAM on the web but most of them are related to flow problems and not the problem that I want to model!
Regards!
hawkeye321 is offline   Reply With Quote
Old   April 14, 2011, 09:07
Default Phase Change in OF
Fabian Roesler
fabian_roesler is on a distinguished road
Hi mahdiiowa
there is no solver in OF like you describe it. You will have to code it by yourself. The solver which just handles scalar transport is the scalarTransportFoam http://openfoamwiki.net/index.php/ScalarTransportFoam. There you have to delete the convective term and add a source term for the enthalpy jump during the phase change. There is much literature around describing the enthalpy method.
Regards
Fabian
fabian_roesler is offline   Reply With Quote
Old   April 16, 2011, 14:29
Dear Fabian
Thanks for you reply!
Old   April 16, 2011, 15:14
Hi
I am now trying to modify scalarTransportFOAM solver! But I cannot where the source file for this solver is!
My directory
Home/OpenFOAM/magma-1.7.1/Run/tutorials/basic/scalarTransportFOAM/pitzDaily
Just contains files
0 constant system
I would be so thankful if someone lets me know how I can find the main solver for scalarTransportFOAM!
Old   April 16, 2011, 15:48
Hi
My directory
Just contains files
0 constant system
Old   April 17, 2011, 04:12
Fabian Braennstroem
braennstroem is on a distinguished road
the attached solver does something similar, I hope it helps... it is based on Zaki Saldi's work. There is a validation case of Solomon's master thesis (I think... it's a long time ago).
Best Regards!
Fabian
braennstroem is offline   Reply With Quote
Old   April 18, 2011, 14:18
Dear Braennstroem
Thank you very much for the file and your kind considerations!
Old   April 18, 2011, 15:16
Dear Braennstroem
Thank you again for the file! I tried to run it in a similar way to running icoFoam!
I set the current directory to
magma@r-soll34:~/OpenFOAM/magma-1.7.1/run/TestMahdi/meltFoam/testCase>
I run the blockMesh!
But when I want to run the meltFoam by typing meltFoam I get the following error
If 'meltFoam' is not a typo you can use command-not-found to lookup the package that contains it, like this:
cnf meltFoam
Would you please help me how to resolve this error!
Regards!
Old   April 19, 2011, 09:36
hossein
hossein.mashhadi is on a distinguished road
Dear Mahdi
i think you have not compiled the solver MeltFoam so first do it and after that you can create a case like IcoFoam tutorial and run MeltFoam.
hope it help you.
hossein.mashhadi is offline   Reply With Quote
Old   April 26, 2011, 17:31
Dear Hossein
I want to compile pisoFoam.C, butI get the following error
mkdir: cannot create directory `linux64GccDPOpt': Permission denied
/bin/sh: linux64GccDPOpt/options: No such file or directory
make: *** [linux64GccDPOpt/options] Error 1
/opt/openfoam171/wmake/MakefileFiles:39: linux64GccDPOpt/options: No such file or directory
make: *** No rule to make target `linux64GccDPOpt/options'. Stop.
wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created
Would you please help me hove to fix it?
Regards
Old   April 27, 2011, 00:25
hossein
Originally Posted by mahdiiowa View Post
Dear Hossein
Regards
Hi Mahdi
i think you should log in as root user (by sudo bash command you can do it) or in file "file" in Make folder change the directory to "FOAM_USER_APPBIN".
i hope it works.
Old   April 28, 2011, 14:35
Dear Hossein
Thank you very much for your help!
I logged in as a root user but now I have another problem even in compiling pisoFoam,(standard solver in Users Guide, Page 70)! the error is this
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/opt/openfoam171/src/turbulenceModels/incompressible/turbulenceModel -I/opt/openfoam171/src/transportModels -I/opt/openfoam171/src/transportModels/incompressible/singlePhaseTransportModel -I/opt/openfoam171/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam171/src/OpenFOAM/lnInclude -I/opt/openfoam171/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed Make/linux64GccDPOpt/pisoFoam.o -L/opt/openfoam171/lib/linux64GccDPOpt \
-lincompressibleTurbulenceModel -lincompressibleRASModels -lincompressibleLESModels -lincompressibleTransportModels -lfiniteVolume -lmeshTools -lOpenFOAM -liberty -ldl -lm -o /opt/openfoam171/applications/bin/linux64GccDPOpt/pisoFoam
/usr/lib64/gcc/x86_64-suse-linux/4.5/../../../../x86_64-suse-linux/bin/ld: cannot find -liberty
collect2: ld returned 1 exit status
make: *** [/opt/openfoam171/applications/bin/linux64GccDPOpt/pisoFoam] Error 1
magma@r-soll34:/opt/openfoam171/applications/solvers/incompressible/pisoFoam>
I do not know why it says "cannot find liberty"!!!
Old   April 29, 2011, 03:53
akidess's Avatar
Anton Kidess
http://www.cfd-online.com/Forums/ope...se-11-2-a.html
Old   April 30, 2011, 14:20
Thank you very much akidess!!!
The problem has been fixed and now I can compile successfully!!!
Old   April 30, 2011, 14:24
I want to edit scalarTransportFoam.C by adding another if loop to it!!! in such a way that for T > 5 ; another term be added to the equation!
I did it this way
for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++)
fvScalarMatrix TEqn
fvm::ddt(T)
+ fvm::div(phi, T)
- fvm::laplacian(DT, T)
if (TEqn> 5)
TEqn += fvm::laplacian(DT, T);
TEqn.solve();
but when I compile it I get the following error
ConductionMT.C: In function ‘int main(int, char**)’:
ConductionMT.C:66:23: error: no match for ‘operator>’ in ‘TEqn > 5’
/opt/openfoam171/src/finiteVolume/lnInclude/readSIMPLEControls.H:6:10: warning: unused variable ‘momentumPredictor’
/opt/openfoam171/src/finiteVolume/lnInclude/readSIMPLEControls.H:9:10: warning: unused variable ‘transonic’
make: *** [Make/linux64GccDPOpt/ConductionMT.o] Error 1
Would you please help me fix the problem??
simulation of phase change material melting rosol FLUENT 4 December 8, 2015 07:56
Two phase flow with phase change Ahmad Al-Zoubi CFX 1 November 26, 2008 03:59
phase change process shen qingqing FLUENT 0 September 7, 2008 09:29
Conduction heat not balanced? Nepal CFX 7 May 31, 2005 11:51
Phase change process Sang-jin Lee Siemens 5 December 5, 2001 05:17
