HOWTO fix mpirun problem
Old   April 28, 2011, 10:21
Default HOWTO fix mpirun problem
JunaidAhmad's Avatar
Junaid Ahmad Khan
JunaidAhmad is on a distinguished road
Hi
i am trying to run OF on multi computers [ip's: 10.9.11.3 and 10.9.11.4]
now when i run command
mpirun --hostfile mechine -np 4 simpleFoam -parallel > log
openfoam@10.9.11.4's password:
mpirun was unable to launch the specified application as it could not find an executable:
Executable: simpleFoam
Node: 10.9.11.4
while attempting to start process rank 2.
So please someone tell me what to do.
I am using Ubuntu 10.10.
JunaidAhmad is offline   Reply With Quote
Old   April 28, 2011, 11:00
longamon's Avatar
David Aljure
Location: CTTC Universidad Politécnica de Catalunya. Spain
longamon is on a distinguished road
try :mpirun -np 4 --hostfile [hostfilename] simpleFoam -parallel > log
also try: foamJob -p simpleFoam with the machines file in the system folder
make sure all nodes have openFoam or can access OF functions. It could be your slave node 10.9.11.4 hasn't OF installed.
see this for more info: http://www.cfd-online.com/Forums/ope...am-solved.html
longamon is offline   Reply With Quote
Old   April 29, 2011, 01:24
Default Thank You
Junaid Ahmad Khan
Thanks a lot............................................... .........you are a life saver
Old   April 29, 2011, 13:21
Junaid Ahmad Khan
i add [source /opt/openfoam171/etc/bashrc]
in the first line of these files
sudo gedit ~/.Profile and gedit ~/.Bashrc
and it worked
SO if anyone have that kind of message then copy and paste the above line
RPI Wall Boiling Problem aliemadi CFX 4 September 1, 2018 21:14
conduction problem venkataramana OpenFOAM 3 December 1, 2013 07:30
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
How to fix this problem? mehul FLUENT 0 February 6, 2007 03:10
