komega turbulence model
Like Tree1Likes
  • 1 Post By romant
Old   January 20, 2012, 04:19
Default komega turbulence model
ahmed
ahmed_khatibs is on a distinguished road
hallo All,
I'm having a little trouble setting up the case in OpenFOAM 1.7 using k-omega SST turbulence model.
What are I need to define (Boundary Condition) for k-omega turbulent model in OpenFoam so as model has to compare with Ansys-Fluent (k-omega standard turbulence model).
Or
which solver I need to take in OpenFoam for compare with Ansys-Fluent (k-omega standard turbulence model).
Thank you
ahmed_khatibs is offline   Reply With Quote
Old   January 20, 2012, 05:07
romant's Avatar
Roman Thiele
romant is on a distinguished road
You will have to decide if you want to run the model in low Reynolds number mode or in high Reynolds number mode. The difference is to have the first cell y+<1 or between 30 and 100. You can then use the following boundary conditions
for low Reynolds mode
k:
all walls
type fixedValue;
value 1e-10;
omega:
all walls
type omegaWallFunction;
nut:
all wall
type nutLowReWallFunction;
high Reynold number mode
k:
all walls
type kqRWallFunction;
omega:
all walls
nut:
all walls
type nutkWallFunction;
in case for the nutkWallFunction, there are different nut wall functions available, which you have to chose yourself in case you have a rough wall or some special wall behavior.
fumiya likes this.
~roman
romant is offline   Reply With Quote
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 13:57
KOmega Turbulence model from wwwopenFOAMWikinet philippose OpenFOAM Running, Solving & CFD 30 August 4, 2010 10:26
SSG Reynolds Turbulence Model Georges CFX 1 February 28, 2007 16:15
Komega turbulence model jasonb OpenFOAM Running, Solving & CFD 6 August 29, 2006 08:46
