June 21, 2011, 09:30 |
need help
gaofeng
hi guys
i just begin to use openfoam for some simulition, and some problems that i cannot understand made me so crazy ,unfortunately the tutoriel didnt help too much so i rly need your help , thank you the following is my blockmeshdict: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.6 | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.01; vertices // definition des points ( (0 0 0) //0 (235 0 0) //1 (265 0 0) //2 (500 0 0) //3 (0 20 0) //4 (235 20 0) //5 (0 180 0 ) //6 (235 180 0) //7 (265 180 0) //8 (500 180 0)//9 (0 200 0) //10 (500 200 0) //11 (0 0 200) //12 (235 0 200) //13 (265 0 200) //14 (500 0 200) //15 (0 20 200) //16 (235 20 200) //17 (0 180 200) //18 (235 180 200) //19 (265 180 200) //20 (500 180 200) //21 (0 200 200) //22 (500 200 200) //23 ); blocks ( hex (0 1 5 4 12 13 17 16) (235 20 1) simpleGrading (1 1 1) hex (4 5 7 6 16 17 19 18) (235 160 1) simpleGrading (1 1 1) hex (1 2 8 7 13 14 20 19) (30 180 1) simpleGrading (1 1 1) hex (2 3 9 8 14 15 21 20) (235 180 1) simpleGrading (1 1 1) hex (6 9 11 10 18 21 23 22) (500 20 1) simpleGrading (1 1 1) ); patches ( patch fixedWalls ( (10 22 23 11) (22 10 6 18) (18 6 4 16) (21 15 3 9) (0 1 13 12) (2 3 15 14) ) patch entree ( (1 2 14 13) ) patch sortie ( (16 4 0 12) (11 23 21 9) ) empty front ( (16 12 13 17) (18 16 17 19) (13 14 20 19) (20 14 15 21) (22 18 21 23) ) empty back ( (0 4 5 1) (4 6 7 5) (1 7 8 2) (2 8 9 3) (10 11 9 6) ) ); i run blockMesh and every thing is ok, but when i run icoFoam ,i get the following error message: --> FOAM FATAL ERROR: This mesh contains patches of type empty but is not 1D or 2D by virtue of the fact that the number of faces of this empty patch is not divisible by the number of cells. From function emptyFvPatchField<Type>::updateCoeffs() in file fields/fvPatchFields/constraint/empty/emptyFvPatchField.C at line 150. so can somebody tell me what problem it is and how i can fix it thank you very much |
June 21, 2011, 09:44 |
David GISEN
Look at your Mesh in Paraview, maybe you see an obvious mistake. i guess some points are mixed up.
PS: your post looks like you were in a hurry, is that true? |
June 21, 2011, 09:47 |
gaofeng
hi david
hehe, you are right , i must figure it out quickly for my intership :s ok i will check it in paraview like you said thank you for your advice |
