what is the magneticFoam for in the OpenFOAM 2.0.0
Old   June 24, 2011, 08:20
Unhappy what is the magneticFoam for in the OpenFOAM 2.0.0
J.Y.Cheng
goodkid is on a distinguished road
Send a message via MSN to goodkid
I have viewed the code of magneticFoam in the OpenFOAM 2.0.0.The code does not involve any equations.what is the code meaning and how to use the magneticFoam.
goodkid is offline   Reply With Quote
Old   June 24, 2011, 08:43
Bernhard
Bernhard is on a distinguished road
From the source.
Description
Solver for the magnetic field generated by permanent magnets.
A Poisson's equation for the magnetic scalar potential psi is solved
from which the magnetic field intensity H and magnetic flux density B
are obtained. The paramagnetic particle force field (H dot grad(H))
is optionally available.
On line 80 you see which equation is solved.
Bernhard is offline   Reply With Quote
Old   June 24, 2011, 09:01
J.Y.Cheng
Thanks.I did not read the code in detail.
Old   November 7, 2011, 04:58
Default searching for an example
maddalena's Avatar
maddalena
maddalena will become famous soon enough
is there anyone having a working example of this magneticFoam? Inside tutorials/electromagnetics/ I have electrostaticFoam and mhdFoam only!
Thank you for sharing,
maddalena
maddalena is offline   Reply With Quote
Old   December 24, 2011, 08:25
Retired Super Moderator
Bruno Santos
Greetings to all!
Another thread thread was created last 7th of December and a case is now available in that thread here: http://www.cfd-online.com/Forums/ope...tml#post336913 post #12.
Feel free to chip in with experience you may have so the case can evolve into something more meaningful than a mere sandbox case.
If that case would evolve into a page at openfoamwiki.net similarly to http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam , that would be awesome
Best regards,
Bruno
magneticfoam, magneticfoam 2.0.0
OpenFoam 2.0.0 installation Jan_Peters OpenFOAM Installation 86 April 27, 2012 05:32
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 05:56
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
OpenFOAM Debian packaging current status problems and TODOs oseen OpenFOAM Installation 9 August 26, 2007 13:50
