reactingFoam - wrong (temperature) profile
Old   July 28, 2011, 09:43
Default reactingFoam - wrong (temperature) profile
Tibo
megacrout is on a distinguished road
Hi everyone,
I used the tutorial of reactingFoam (counterFlowFlame2D) to simulate an adiabatically reacting stream flowing through a pipe.
All I modified is blockMesh and the boundary conditions accordingly (kept the already existing inlet, outlet and empty conditions, added wedge conditions where needed and looked at some other tutorials for the remaining side: the pipe wall).
Reaction, physical properties, constants, equations, schemes, initial conditions... I´m pretty sure all other parameters remained unchanged. I just checked it out again and it looks so.
However, I get ridiculously high temperatures (up to 4500K). When I implement turbulent conditions, it gets even worse and the sadly famous Janaf error pops out.
After some basic Google research, it seems T should not exceed ca. 2200-2300K. The tutorial actually leads to a maximal temperature of about 2300K.
I expect the mistake to come from the boundary conditions I implemented for the pipe wall but I can´t say which one(s) are wrong exactly. I´d be glad if someone could help me finding it out.
All case files (0, constant, system) are in the appendix.
Even though it´s using reactingFoam, the computation does not last too long (not even 10minutes on my laptop).
Many thanks in advance.
Tibo
megacrout is offline   Reply With Quote
Old   August 1, 2011, 05:11
Tibo
Can anyone help, please?
boundary conditions, counterflowflame, reactingfoam, temperature profile
Appling a linear temperature profile to a surface safikhani_hamed FLUENT 0 December 8, 2010 14:59
reactingFoam: adiabatic flame temperature rFkhemek OpenFOAM 2 July 31, 2009 06:42
giving temperature profile nag FLUENT 1 May 26, 2008 18:50
Parabolic temperature Inlet Profile in a tube majestywzh FLUENT 0 April 9, 2003 06:37
temperature profile on boundary sivakumar FLUENT 5 November 24, 2002 00:58
