flux conservation after mesh refinement
Old   August 13, 2011, 19:21
Question flux conservation after mesh refinement
Alin Anton
aanton is on a distinguished road
Hello folks,
I am trying to understand and implement the procedure described in 5.4 of Prof. Jasak's Thesis, and on pages 143-146, for preserving the flux conservation. That is, I need to solve the pressure equation again, and obtain conservative fluxes on a new, refined mesh. I come from computer science, and I am not a CFD user, but my field of study (CiSE) has confluenced with CFD and I am stuck with some problems. I will appreciate any help, gratefully ask for it, and I appologize for possibly poor/obvious questions/solutions. Thanks .
Question 1: If i am running an unsteady simulation, and at some moment proceed to refine the mesh and map the fields (using mapFields) from the coarse mesh to the new mesh, provided that the refinement zone is not located anywhere on the inlet or outlet, do I need to worry about violating mass conservation? I am working with incompressible flows, with the pimpleFoam solver.
Question 2: From what I understood on page 236, I edited the pEqn.H from the pimpleFoam solver and simply added the two lines to the end of it that are present in the beginning of the file, for flux calculation:
phi = (fvc::interpolate(U) & mesh.Sf()) + fvc::ddtPhiCorr(rUA, U, phi);
adjustPhi(phi, U, p);
I hope these wont get scrambled by the editor. Anyway, could you please comment on this implementation? What I am trying to do is solving the pressure equation again, and afterwards obtaining conservative fluxes.
Question 3: Can I skip solving UEqn? Can I comment out all lines that modify U in UEqn.H, including relaxation, solve(), etc, and restrict the procedure to solving pEqn.H with interpolated U values? It is faster and does not modify the velocity field.
Question 4: Can I skip the PISO-SIMPLE loop, meaning that I simply call pEqn.solve() or solve(mesh.solver("pFinal"))? How bad is it? All I need is conservative fluxes not different p -> current p, along with k and nuSgs are interpolated on the new mesh.
Question 5 (last): In order to avoid unboundedness problems, do I need to actually save all the updated values for p, k, nuSgs, U along with the face flux field phi? Or all I need is pEqn.solve() , and phi?
Thank you in advance, I appreciate and value your time, help and advices. I know some questions overlap, it seems easier this way to pinpoint the issues.
I am also aware of the two following threads:
http://www.cfd-online.com/Forums/ope...eld-known.html
http://www.cfd-online.com/Forums/ope...u-mesh-sf.html
Thank you guys,
/A
aanton is offline   Reply With Quote
conservation, flux, refinement
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
[snappyHexMesh] snappyHexMesh not refining surfaces Hydro1004 OpenFOAM Meshing & Mesh Conversion 3 August 29, 2012 11:56
Mesh refinement and the errors. Korsh Mik CFX 0 January 11, 2006 07:07
