[swak4Foam] Trouble setting groovyBC interFoam Inlet BC |
June 30, 2012, 14:37 |
Matthew Denno
Rep Power: 16 |
As indicated in the post title, I am trying to use groovyBC to set the inlet boundary condition for a interFoam simulation. I am using OpenFOAM 2.1.0 running on kubuntu 11.10. The attached picture (colored as p_rgh) shows a 2D view of the problem which is flow in a channel over a spillway. The inlet is on the right, the outlet is on the left, top is atmosphere, bottom is wall, and front and back are symmetry plane. Historically I have split my inlet patch into 2 separate patches, one for air and one for water. I was hoping that I would be able to use groovyBC to accomplish the same thing with one patch so that I can change the inlet water level without changing my mesh. Anyway, the simulation seems to run ok, and the water surface looks ok (although I haven't compared to physical model data yet), but the pressure at the inlet seems to be funky. You can see in the picture that the p_rgh is 0 at the inlet, and p (not shown) has a significant negative pressure at the inlet. This seems incorrect to me. Can anyone provide any insight regarding what is happening? Are my boundary conditions (below) specified incorrectly? p_rgh: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 0; boundaryField { top { type totalPressure; p0 uniform 0; U U; phi phi; rho rho; psi none; gamma 1; value uniform 0; } bottom { type buoyantPressure; value uniform 0; } inlet { type buoyantPressure; value uniform 0; } outlet { type totalPressure; p0 uniform 0; U U; phi phi; rho rho; psi none; gamma 1; value uniform 0; } walls { type symmetryPlane; } wes { type buoyantPressure; value uniform 0; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object alpha1; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 0 0 0 0]; internalField uniform 0; boundaryField { top { type inletOutlet; inletValue uniform 0; value uniform 0; } bottom { type zeroGradient; } inlet { type groovyBC; valueExpression "1"; fractionExpression "(pos().z<28) ? 1 : 0"; value uniform 1; } outlet { type inletOutlet; inletValue uniform 0; value uniform 0; } walls { type symmetryPlane; } wes { type zeroGradient; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; location "0"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { top { type pressureInletOutletVelocity; value uniform (0 0 0); } bottom { type slip; } inlet { type groovyBC; valueExpression "(pos().z<28) ? vector(1.981,0,0) : vector(0,0,0)"; value uniform (0 0 0); } outlet { type inletOutlet; inletValue uniform (0 0 0); value uniform (0 0 0); } walls { type symmetryPlane; } wes { type slip; } } // ************************************************************************* // |
interFoam vs. simpleFoam channel flow comparison | DanM | OpenFOAM Running, Solving & CFD | 12 | January 31, 2020 15:26 |
interFoam (HELYX-OS) pressure boundary conditions | SFr | OpenFOAM Running, Solving & CFD | 8 | June 23, 2016 16:36 |
problem with inlet BC setting | Tanjina | Fluent Multiphase | 4 | July 1, 2013 13:06 |
[swak4Foam] Scale discrete inlet velocity profile with groovyBC | cboss | OpenFOAM Community Contributions | 1 | June 20, 2010 13:02 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
