May 30, 2022, 10:06 |
Lagrangian Particle OpenFOAM
Rep Power: 4 |
Hello. I made a simulation of the motion of Lagrangian particles using the "particleFoam" solver. Each particle was counted separately and then I put them on one graph. It seems to me that I got the wrong trajectories because the particles practically do not rise along the "x" axis. What could be the mistake?
P,S, At the beginning I counted the inviscid gas using "rhoCentralFoam". Then I took the velocity and density distribution and worked with the "particleFoam" solver. |
June 9, 2022, 08:13 |
Josh Williams
Rep Power: 5 |
Have you tried running the simulation with "coupled" as true? I think this is the issue.
June 13, 2022, 13:43 |
Rep Power: 4 |
thanks for the reply. I consulted with some people and realized that I got a fairly correct result. And what is the "coupled" setting. And what it affects. When I ran the simulation with "true" I didn't get the change.
lagrangian particle, openfoam, particlefoam, rhocentralfoam |
Lagrangian particle tracking cannot be run in parallel for the cases with AMI patches | Armin.Sh | OpenFOAM Running, Solving & CFD | 7 | March 28, 2021 22:33 |
Lagrangian data - particle velocity post processing | Ake | OpenFOAM Post-Processing | 12 | August 16, 2020 07:54 |
Lagrangian Particle, first particle integration step wrong dt and age? | Sverre Magnus | OpenFOAM Programming & Development | 0 | February 13, 2020 05:39 |
Post processing of Lagrangian particle field | marialhm | OpenFOAM Post-Processing | 0 | October 8, 2017 22:02 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
