[swak4Foam] installing funkySetFields utility for OpenFOAM 1.4.1
Like Tree1Likes
  • 1 Post By brugiere_olivier
Old   June 26, 2009, 10:48
Default installing funkySetFields utility for OpenFOAM 1.4.1
ozie
ozie is on a distinguished road
Hello everybody,
I`am new to OpenFOAM. I just tired to compile funkysetField utility. And i had the error message below;
funkySetFields.C:43:26: error: timeSelector.H: Aucun fichier ou répertoire de ce type
funkySetFields.C: In function ‘int main(int, char**)’:
funkySetFields.C:193: error: ‘Foam::timeSelector’ has not been declared
funkySetFields.C:220: error: ‘Foam::timeSelector’ has not been declared
make: *** [Make/linuxGccDPOpt/funkySetFields.o] Erreur 1
So I checked funkySetFields.C. And I noticed that timeSelector.H is needed to run this program. Indeed, this file doesn`t exist among the funkySetFields files therby causing errors...
Does anyone could tell me how to find timeSelector.H, or maybe am I doing something wrong when compiling funkySetField?
oguz,
ozie is offline   Reply With Quote
Old   June 29, 2009, 05:02
Default Solution to install funkySetFiel
Brugiere Olivier
brugiere_olivier is on a distinguished road
Hi all
If you want install funkySetFiel, follow this step :
- go to http://openfoamwiki.net/index.php/Co...funkySetFields
- read the step seven and use the "svn checkout" command to have the funkySetFields
- check if you have bison with bison -V
- then go in the FunkySetFields/funkySetFields
- ./insertGenerated.sh
- wmake
And normaly funkySetFields was completly instal.
Olivier
salarbe likes this.
brugiere_olivier is offline   Reply With Quote
Old   June 29, 2009, 12:03
Assistant Moderator
Bernhard Gschaider
Originally Posted by ozie View Post
Hello everybody,
Obviously you're trying to compile the 1.5-version. This won't work on 1.4.1. Have a look at http://openfoamwiki.net/index.php/Co...ields#Download to get a version of FSF that is right for your installation
Bernhard
Old   June 29, 2009, 12:07
isabel
isabel is on a distinguished road
When I try to execute FunkySetField I have this error:
bash: funkySetFields: command not found
Does anybody know why?
isabel is offline   Reply With Quote
Old   June 29, 2009, 12:21
Assistant Moderator
Bernhard Gschaider
No. There are 2 possibilities:
  1. It did not compile correctly in the first place
  2. It was not stored into a directory that is in the PATH-environment-variable (one cause might be: compilation under another username)
Bernhard
Old   September 8, 2011, 08:40
Default executing in openfoam 1.7.x
Mohammad Fereshtehpour
MOHAMMAD67 is on a distinguished road
Send a message via Skype™ to MOHAMMAD67
Hi bernard
I download it in a folder swake4foam in the home directory. what should I do to run funkysetField? ( I'm new to linux and openfoam)
Is funkysetField able to set free surface flow in pipe?
MOHAMMAD67 is offline   Reply With Quote
Old   September 8, 2011, 09:44
Assistant Moderator
Bernhard Gschaider
Originally Posted by MOHAMMAD67 View Post
Hi bernard
swak4Foam won't work with OF 1.4.1, sorry.
If you're using a supported version and only posted in an inappropriate thread: the information you need about compiling is just at the top of the README
funkySetFields allows you to set arbitrary initial conditions for your problems (see examples on the funkySetFields-page on the OpenFOAM-Wiki)
Bernhard
Old   September 8, 2011, 10:06
Default FSF application for free surface flow
Thanks bernard
I use openfoam 1.7.x. I could successfully run funkesetfield for dambreak. But I don't know how to make it for free surface flow for a problem like pitzdaily(discussed in this thread).
Old   September 8, 2011, 11:16
Assistant Moderator
Bernhard Gschaider
Thanks bernard
I'm not quite sure what you mean with "free surface flow". You mean a VOF-calculation? In that case FSF can only help you by setting the initial conditions (for alpha for instance). The actual calculation has to be done with the appropriate solver (interFoam for instance)
Bernhard
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 02:36
[swak4Foam] installing funkySetFields prapanj OpenFOAM Community Contributions 65 October 8, 2015 17:46
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
Something doens't work with wallHeatFlux utility or externalWallHeatFluxTemperat BC!! zfaraday OpenFOAM Post-Processing 0 February 5, 2015 16:47
[swak4Foam] installing funkySetFields igo OpenFOAM Community Contributions 1 November 20, 2012 20:16
