February 23, 2012, 06:07 |
OpenFoam for HVAC Applications
ATE
Hi ,
I am new to OpenFOAM. Can anybody please help software is how much capabilities to do room air flow distribution, Co2 and H2o concentration calculation, temperature and veocity distributions inside room and HVAC applications. Thanks & regards ATE |
February 23, 2012, 07:00 |
A_R
Rep Power: 16 |
you can develop your code to do all these things. it depends on yourself.
open-foam is a strong code for cfd purposes. |
February 23, 2012, 09:30 |
Download ICON hvacFOAM 1.7 (Audi Suppliers) http://iconcfd.com/de/customer-support/hvacfoam never used it myself, just heard of it =>but I believe it is not that easy to use that out of the box, but perhaps better than nothing. OF is quite often used for Aircraft Cabin simulations http://www.openfoamworkshop.org/6th_...r_webel_ab.pdf just as an example Are you professionally interested in HVAC => you might be interested to spend some money to some of the consulting companys (Engys or Icon ...) and get a working HVAC enviroment + solver + training etc. I am not affiliated with any OF consulting company ;-). Last edited by elvis; February 23, 2012 at 09:48. |
March 21, 2012, 07:02 |
ATE
thank you elvis.. i downloaded ICON hvacFOAM 1.7 from mentioned link above..Can u please give me the idea about how to install the software ..is there any link of this software with OpenFOAm..and if possible from where i will get documnetation or tutorials of this software..
thank you .. uday.... |
March 22, 2012, 03:31 |
Dear ATE,
sorry I can not help you very much, I just knew the existance of the HVAC solver from them. First if all I want to say that hvacFOAM 1.7 was developed on OF 1.7, so to get it run, you should have a OF 1.7 installation. the OpenFoam team changed things heavilly during the versions from time to time and to make the nescessary changes to transfer solver from 1.7 to 2.x can be tricky! Maybe a good start to get used to tasks you have to cope with is these links http://web.student.chalmers.se/group...g/UserView.pdf http://www.openfoamworkshop.org/2009...ng/Cpp4Cfd.pdf http://www.openfoamworkshop.org/2009...ngTutorial.pdf http://openfoamwiki.net/index.php/Op...de/Use_bananas |
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 7 | January 19, 2010 15:39 |
Different flow pattern between OpenFOAM and CFX | AirS | OpenFOAM | 0 | January 12, 2010 07:08 |
Problem installing OpenFOAM 1.5 installation on RHEL 4. | vwsj84 | OpenFOAM Installation | 4 | April 23, 2009 04:48 |
2009 OpenFOAM Summer School in Zagreb, Croatia | hjasak | OpenFOAM Announcements from Other Sources | 0 | March 27, 2009 12:08 |
The OpenFOAM extensions project | mbeaudoin | OpenFOAM | 16 | October 9, 2007 09:33 |
