[OpenFOAM] ParaFoam over SSH - cannot connect to X server
Like Tree2Likes
  • 2 Post By mturcios777
Old   July 17, 2012, 18:03
Default ParaFoam over SSH - cannot connect to X server
uli
uli is on a distinguished road
hi all
Running a simulation over ssh works, but when I type "paraFoam" it gives me
I use opensuse 11.4, the server I am connected to has ubuntu.
I also set up a connection with XMing and Putty on Windows, there it works.
Any suggestions?
thanks,
Uli
uli is offline   Reply With Quote
Old   July 17, 2012, 19:31
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
What command are you running to connect to your server? First thing I would make sure is that X forwarding is allowed. You have the -X/-Y option in your command to enable X forwarding?
roamer and jjulien like this.
mturcios777 is offline   Reply With Quote
Old   July 19, 2012, 17:54
uli
hi Marco, thanks for your reply.
Sorry, my bad. I forgot the -X.
But it gives me another error:
ssh -X myname@ipadress
and when I run "paraFoam" in the case-directory the "welcome" Window of ParaView opens but after a few seconds I get
created temporary 'cavity.OpenFOAM'
Segmentation fault (core dumped)
thanks
Uli
Old   July 19, 2012, 18:16
Marco A. Turcios
It seems like X forwarding is working as you got the welcome screen. Does this happen with both -X and -Y options?
Old   July 20, 2012, 05:15
Retired Super Moderator
Bruno Santos
Greetings to all!
This comes to mind:
Originally Posted by preichl View Post
I had similar errors when connecting via ssh to the machine running paraview (even with paraview 3.8.1).
Setting the environment variable via the command below worked for me.
export LIBGL_ALWAYS_INDIRECT=y
I tried this after reading http://ubuntuforums.org/showthread.php?t=1098568
Hope this helps anyone else in the same boat.
Best regards,
Bruno
command not found issue through an ssh server Salim OpenFOAM 12 November 20, 2022 12:58
error: connect failed destroy FLUENT 7 March 18, 2018 14:59
[General] Mac Os x system can't connect to X server when using ssh to access Linux system Ivy Zhou ParaView 2 September 30, 2013 10:21
Connect to server LaGurk STAR-CCM+ 8 May 6, 2012 08:39
[OpenFOAM] Weird Problem with ParaFoam via SSH cwang5 ParaView 2 July 19, 2010 09:00
