April 23, 2013, 07:44 |
problem in para veiw
rehan
hello Foamers
after running the openfoam the inthe para view wen i click apply tab it gives following error borted (core dumped) user@ubuntu:~/OpenFOAM/user-2.2.0/run/waterChannel$ paraFoam created temporary 'waterChannel.OpenFOAM' fileName::stripInvalid() called for invalid fileName alpha1~ For debug level (= 2) > 1 this is considered fatal Aborted (core dumped) user@ubuntu:~/OpenFOAM/user-2.2.0/run/waterChannel$ ^C user@ubuntu:~/OpenFOAM/user-2.2.0/run/waterChannel$ paraFoam created temporary 'waterChannel.OpenFOAM' please help... |
April 23, 2013, 08:42 |
#2 | |
Phillip
But, do something like this:
April 23, 2013, 09:48 |
Jose Rey
Another thing you can try is the command line foamToVTK, and then open the generated VTK files from paraview (not paraFoam). If this approach works, then your problem might be in the paraFoam installation, if this approach doesn't work, then your problem is likely in your mesh/solution.
April 24, 2013, 00:56 |
rehan
hey phillip,
thanks for the reply and it worked... |
April 24, 2013, 01:13 |
rehan
hello Phillip,
can you please explain what is the reason for skipping the the zero timestep? |
April 24, 2013, 04:11 |
Phillip
[Other] engineFoam new mesh problem | ayhan515 | OpenFOAM Meshing & Mesh Conversion | 5 | August 10, 2015 08:45 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
