[General] Problem opening Ensight File
Old   July 3, 2013, 09:41
Default Problem opening Ensight File
Jeff
Jeff74A is on a distinguished road
Hi everybody,
I am currently trying to use Paraview to open an Ensight File (.case) as it should be okay as stated in the Paraview Manual.
However, I can not open this Ensight file and the following message appears :
__________________________________________________ _____________
ERROR : In C:\DBD\pvs-x64\paraview\src\paraview\VTK\IO\Ensight\vtkGeneri cEnsightReader.cxx, line 572
vtkPGenericEnsightReader (000000001379DBC0) : Unable to open file :
C:\Users\Dekstop\20130530_01.ensight\ /_01.geo000
Warning : In C:\DBD\pvs-x64\paraview\src\paraview\VTK\IO\Ensight\vtkGeneri cEnsightReader.cxx, line 573
vtkPGenericEnsightReader (000000001379DBC0) : Assuming binary file.
Here is the part of the Paraview code of the vtkGenericEnsightReader.cxx (l.572 in red) :
// got full path to geometry file
this->IFile = fopen(sfilename.c_str(), "rb");
if (this->IFile == NULL)
if (!quiet)
vtkErrorMacro("Unable to open file: " << sfilename.c_str());
vtkWarningMacro("Assuming binary file.");
this->IFile = NULL;
delete [] fileName;
return vtkGenericEnSightReader::ENSIGHT_6_BINARY;
} // end if IFile == NULL
Obviously, I have a problem of geometry.
Here is the beginning of the case file to call for the file for geometry :
FORMAT
type: ensight
GEOMETRY
model: 1 20130530_01.geo***
VARIABLE
scalar per element: Densite 20130530_01.den***
scalar per element: Pression 20130530_01.pre***
scalar per element: Temperature 20130530_01.tem***
- Is there a problem in the way the .case file is written to call the geometry ?
- I can not display the geometry file itself as it is coded in binary language. Could the problem come from that as well ?
Thank you very much for any help you could provide me with .
Do not hesitate to ask any more precision or detail !
Jeff74A is offline   Reply With Quote
Old   July 7, 2013, 05:52
Retired Super Moderator
Bruno Santos
Greetings Jeff and welcome to the forum!
Please use the "[CODE]" tag for posting code... it's explained in the second link in my signature
From the description you've given, the problem seems to be because ParaView is having a hard time understanding that the file name should be "20130530_01.geo" and not "/_01.geo".
The other possibility is that the file "20130530_01.geo" doesn't exist and leads ParaView to try to look for the file "/_01.geo" instead.
Best regards,
Bruno
Old   July 22, 2013, 03:42
Jeff
Hello Wyldckat,
thank you very much for your answer.
I have finally found out where the problem was coming from : it seems that Paraview has some hard times when it comes to ENSIGHT 6 format. (I asked other people and they told me ther same thing). ENSIGHT gold is said to be better.
Thanks again for your answer.
Bye.
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 10:03
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 11:32
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
