[General] Error initiating pvserver on Windows
Like Tree1Likes
  • 1 Post By wyldckat
Old   October 18, 2013, 15:20
Default Error initiating pvserver on Windows
circuitBurn is on a distinguished road
I've just downloaded and installed the latest version of Paraview (4.0.1) using the pre-built binaries. I've been trying, unsuccessfully, to start a paraview server with the intention of developing an app that will incorporate ParaViewWeb.
Here's the error:
C:\Program Files (x86)\ParaView 4.0.1\bin>pvserver.exe
[Objectivity103:06768] [[INVALID],INVALID] ERROR: Failed to identify the local daemon's URI
[Objectivity103:06768] [[INVALID],INVALID] ERROR: This is a fatal condition when the binomial router
[Objectivity103:06768] [[INVALID],INVALID] ERROR: has been selected - either select the unity router
[Objectivity103:06768] [[INVALID],INVALID] ERROR: or ensure that the local daemon info is provided
[Objectivity103:06768] [[INVALID],INVALID] ORTE_ERROR_LOG: Fatal in file C:\DBD\pvs-x64\mpi\src\mpi\
orte\mca\ess\base\ess_base_std_app.c at line 151
Sorry!  You were supposed to get help about:
    orte_init:startup:internal-failure
But I couldn't open the help file:
    C:\DBD\pvs-x64\install\share\openmpi\help-orte-runtime.txt: No such file or directory.  Sorry!
orte\mca\ess\singleton\ess_singleton_module.c at line 277
orte\runtime\orte_init.c at line 132
    C:\DBD\pvs-x64\install\share\openmpi\help-orte-runtime: No such file or directory.  Sorry!
    mpi_init:startup:internal-failure
    C:\DBD\pvs-x64\install\share\openmpi\help-mpi-runtime: No such file or directory.  Sorry!
*** The MPI_Init() function was called before MPI_INIT was invoked.
*** This is disallowed by the MPI standard.
*** Your MPI job will now abort.
[Objectivity103:6768] Abort before MPI_INIT completed successfully; not able to guarantee that all o
ther processes were killed!
Running
mpirun -np 4 ./pvserver
as the docs say doesn't help me much either.
C:\Program Files (x86)\ParaView 4.0.1\bin>mpirun -np 4 ./pvserver
    orterun:exe-not-accessible
    C:\DBD\pvs-x64\install\share\openmpi\help-orterun.txt: No such file or directory.  Sorry!
4 total processes failed to start
I'm really new to using ParaView so I feel like I've missed a step somewhere along the line but I can't find any documentation to help point me in the right direction.
Thanks
EDIT: I should point out that those hardcoded paths (C:\DBD\pvs-x64\mpi\src\mpi\
orte\mca\ess\singleton\ess_singleton_module.c at line 277) are a mystery to me.
circuitBurn is offline   Reply With Quote
Old   October 18, 2013, 15:59
Well, I've answered my own problem by installing MPICH2 from here:
http://www.mpich.org/downloads/
and running
mpiexec -np 4 $PATH_TO_PARAVIEW\bin\pvserver
However, I'm getting the following error:
C:\Program Files\MPICH2\bin>mpiexec -np 1 -host localhost C:\Program Files (x86)\ParaView 4.0.1\bin\
pvserver
Error while connecting to host, No connection could be made because the target machine actively refused it. (10061)
Connect on sock (host=localhost, port=8676) failed, exhaused all end points
Unable to connect to 'localhost:8676',
sock error: Error = -1
Old   October 19, 2013, 05:14
Retired Super Moderator
Bruno Santos
Greetings circuitBurn and welcome to the forum!
ParaView 4.0.1 on Windows uses Open-MPI 1.4.4: http://paraview.org/Wiki/ParaView/Binaries
As for another detail, I'll quote myself from another thread:
Originally Posted by wyldckat View Post
You can try turning on the multi-core feature that ParaView has got, if it was built with MPI capabilities, which is accessible at the Settings dialogue, namely the check box "Use Multi-Core": http://www.paraview.org/Wiki/ParaVie...Guide/Settings
Wait... I forgot that you wanted to use it for ParaViewWeb...
Mmm... I'll get back to you later today, when I have a Windows machine at hand.
Best regards,
Bruno
Old   October 19, 2013, 16:45
Bruno Santos
Hi circuitBurn,
OK, I got my hands on one of my Windows machines. Here's what you'll have to do:
  1. Go into the folder where ParaView is installed, but from the Windows command line. For example:
    cd C:\Program Files (x86)\ParaView 4.0.1
  2. Now you have to create a temporary drive letter that points to this folder, because Open-MPI hates paths with spaces:
    subst F: .
  3. Now switch to the temporary drive letter, as exemplified above, and go into the "bin" folder:
    F:
    cd bin
  4. Now, to launch pvserver, you have to run like this (e.g. with 2 parallel processes):
    mpirun -np 2 F:\bin\pvserver.exe
  5. And it should now be running as expected!
  6. Once it's over and if you want to turn off the temporary drive letter, run:
    C:
    subst F: /D
Best regards,
Bruno
Iose likes this.
Old   October 20, 2013, 17:16
wyldckat, thank you SO much. I am just about to start building paraview on my machine here at home and I'll let you know the outcome.
Old   October 21, 2013, 11:24
Worked like a charm. Thanks again for your help On to other issues now!
paraview, pvserver
Compile Fluent UDF with Windows 10 daniel_pramudita FLUENT 15 May 13, 2020 22:29
[OpenFOAM.com] v1712 with Docker on Ubuntu 17.10. Use same docker in Windows 10? amh@inventas.no OpenFOAM Installation 0 January 30, 2018 08:59
Caelus: fork of OpenFOAM cnsidero OpenFOAM Announcements from Other Sources 7 November 11, 2014 22:55
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
