[General] Custom Filter to Extract Selection Based on Cell_Data Informations
Old   April 29, 2014, 08:40
Default Custom Filter to Extract Selection Based on Cell_Data Informations
Alessandro
ronwelty is on a distinguished road
I would like to extract a certain number of cells out of my model, based on informations defined by a cell_data vector. In particular, I would like to use the "extract selection" filter on all the cells which have a displacement lesser or equal to a given value. I would need to do this automatically at every step, since the displacement is obviously varying with respect to time.
Any idea?
Thanks.
ronwelty is offline   Reply With Quote
Old   April 30, 2014, 13:10
Retired Super Moderator
Bruno Santos
Hi Alessandro,
The "Threshold" filter is able to extract only the cells with values within a certain range.
Problem is (if my memory doesn't fail me) that this filter only operates based on a scalar field, which means that you might need the "Calculator" filter to do some calculations first... for example, to calculate the magnitude of the displacement.
Best regards,
Bruno
how to extract the LES filter delta in creatField.H hz283 OpenFOAM 1 November 22, 2022 14:30
[ANSYS Meshing] Script Connection Friction arpeedesign ANSYS Meshing & Geometry 4 April 11, 2019 08:17
[DesignModeler] New Selection, Edge filter for undo cfd-eng ANSYS Meshing & Geometry 0 June 1, 2017 12:29
Dynamic Smagorinsky model- Filtering Concept saeedi Main CFD Forum 34 November 29, 2015 22:43
[OpenFOAM] Segmentation fault when using Glyph from Custom Source Filter in ParaFoam jstol065 ParaView 1 September 20, 2015 22:07
