[OpenFOAM] How to plot alpha vs time graph in multiphase solver of openFOAM
Old   March 1, 2015, 08:58
Default How to plot alpha vs time graph in multiphase solver of openFOAM
Baris (Heewa)
shipman is on a distinguished road
Hi to everyone,
I am using interPhaseChangeFoam to simulate the phase cavitation inside the nozzle in OpenFOAM. I found out that To plot alpha vs time graph using foamCalcEx with volIntegrate is one way and i did it. But i would like to ask that does anyone know how to plot this graph directly inside paraview when i view the case?
Thanks in advance.
shipman is offline   Reply With Quote
Old   March 3, 2015, 00:38
Baris (Heewa)
Ok it is found...
If someone also wants learn the way how to plot please leave message here...
Thank you
Old   April 15, 2015, 05:11
Duong Tung
gnut1989 is on a distinguished road
Originally Posted by shipman View Post
Ok it is found...
Thank you
Hi Baris,
I want to learn the way which plot anpha with time you had already done. Could you please help me to do it?
Thank you and best regards,
Duong Tung
gnut1989 is offline   Reply With Quote
Old   April 22, 2015, 12:31
Noraa
Noraa is on a distinguished road
Hello Duong ,
I had the same problem just follow this link it will work:
http://www.cfd-online.com/Forums/ope...-paraview.html
good luck,
Noraa is offline   Reply With Quote
Old   April 24, 2015, 01:27
Baris (Heewa)
Hi Duong,
Sorry again to late answer. As i said i am great busy with PhD thesis stuffs. As Noraa said that it is one way to get alhpa vs time. Another and simple way is to use foamCalcEx volIntegrate.
How to use this is explained here: https://openfoamwiki.net/index.php/Contrib_foamCalcEx
Hope this helps.
BR
Baris
Old   June 10, 2015, 11:57
Konstantin
DzhoniD is on a distinguished road
Hi to everyone,
I have some problem with ploting over time. I'm using OpFm and Paraview over 3 months, but can't understand how using "plot variables over time" or "plot selection over time".
I'm solving "damBreak" problem by InterFoam solver, so i need to plot changing of "alpha1" over time in certain plane. For now i trying to use "sampleDict", but it write only the data in separate files, so this is not very convenient.
I can't using foamCalcEx, because my version of OpenFoam (OF-Ex 3.1) is not supported. And I read this topic http://www.cfd-online.com/Forums/ope...-paraview.html, but I see that my version of Paraview is 4.3.1...
Can someone explain to me in details how to use Paraview for solving my "stupid" problem?
P.S.: sorry for my english.
Thanks for all,
DzhoniD
DzhoniD is offline   Reply With Quote
Old   August 5, 2018, 23:22
Elham
Elham is on a distinguished road
Hi Duong,
Hope this helps.
BR
Baris
I have used foamCalc with different options. One of them is
foamCalcEx volIntegrate alpha.water -latestTime
but it seems that it calculates the 0 time even after specifying another time, like following:
Create time
Create mesh for time = 0
Time = 0
    Reading alpha.water
    Calculating volIntegrate(alpha.water): domainIntegrate(alpha.water) [0 3 0 0 0 0 0] 3.34545e-09
End
Does anyone knows the reason?
Cheers,
Elham
Elham is offline   Reply With Quote
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 02:36
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 05:28
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 09:34
OpenCL linear solver for OpenFoam 1.7 (alpha) will come out very soon qinmaple OpenFOAM Announcements from Other Sources 4 August 10, 2012 11:00
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
