[General] Integral average of velocity values on a slice
Like Tree1Likes
  • 1 Post By Flowkersma
Old   October 5, 2015, 15:56
Default Integral average of velocity values on a slice
cfdaddicted is on a distinguished road
I need to evaluate the integral average of velocity values on a slice in ParaView 4.3.1.
I want to obtain a plot of the axial velocity of water as a function of radial position in a cylinder.
Is it possible to perform this in ParaView or not?
If I need to export the data, how could I automate the process of slice selection along the axial direction?
Thank you in advance.
cfdaddicted is offline   Reply With Quote
Old   October 12, 2015, 08:09
Mikko
Flowkersma is on a distinguished road
Everything is possible with ParaView However, I'm not sure if I understand your question. If you have a cross section of a pipe and you want to get the average velocity over radial distance try following:
  1. Calculate the radial distance (Calculator)
  2. Create one isocontour line with constant radial distance (Contour)
  3. Integrate (IntegrateVariables)
  4. Calculate average and save the result
For different radial distances, just change the isocontour value. Here is an example code for a pipe which axis is in z-direction:
import numpy as np
import matplotlib.pyplot as plt
from paraview import numpy_support as ns
# Result arrays
U = []
R = []
# Build a pipeline
slice = GetActiveSource()
calc = Calculator(slice, ResultArrayName = 'radius', Function = 'sqrt(coordsX^2+coordsY^2)')
contour = Contour(calc,ContourBy = ['POINTS','radius'],Isosurfaces = [0])
int = IntegrateVariables(contour)
# Loop over different radial distances and save the results
for r in np.arange(0.05,0.5,0.05):
   contour.Isosurfaces = [r]
   intData = servermanager.Fetch(int)
   L = ns.vtk_to_numpy(intData.GetCellData().GetArray('Length'))[0]
   U.append(ns.vtk_to_numpy(intData.GetPointData().GetArray('U'))[0][2]/L)
   R.append(r)
#plot with matplotlib
plt.plot(U,R)
plt.show()
Regards,
Mikko
Flowkersma is offline   Reply With Quote
Old   November 9, 2015, 17:58
Felipe Alves Portela
fportela is on a distinguished road
Hi Mikko,
I've been trying your suggestion below (as you suggested in another thread) but I keep getting a segmentation fault at the "servermanager.Fetch" stage. Any idea why this may be happening? I'm running version 4.3.1 btw
Originally Posted by Flowkersma View Post
import numpy as np
# Result arrays
U = []
R = []
# Build a pipeline
   R.append(r)
plt.plot(U,R)
plt.show()
Regards,
Mikko
fportela is offline   Reply With Quote
Old   November 10, 2015, 05:25
Mikko
Hi Felipe,
I haven't encountered segmentation fault there. Have you succeeded to fetch data before? Have you checked your RAM consumption? Can you share your script?
Old   November 10, 2015, 05:36
Well, tbh this is my first go at using python scripts in ParaView so I guess I have never succeeded to fetch data before x)
I load a .csv file and convert it to points using the TableToPoints filter, then I generate a volume by using the Delaunay3D filter, then I want to compute the integral over several surfaces (which seems to work when I manually generate the contours)
As for the memory, nothing weird seems to happen... I tried both on a mac and a linux machine and the same thing happens on both!
The script I used for the integration is this (adapted from the one you posted):
import numpy as np
import paraview as pv
import paraview.simple as ps
# Result arrays
U = []
R = []
# Build a pipeline
slice = ps.GetActiveSource()
calc = ps.Calculator(slice, ResultArrayName = 'radius', Function = 'sqrt(coordsX^2+coordsY^2+coordsZ^2)')
contour = ps.Contour(calc,ContourBy = ['POINTS','radius'],Isosurfaces = [0])
int = ps.IntegrateVariables(contour)
for r in np.arange(0.1,1.5,0.1):
   intData = pv.servermanager.Fetch(int)
   R.append(r)
Hi Felipe,
Old   November 10, 2015, 16:27
Mikko
Hmm.. can you try
intData = ps.servermanager.Fetch(int)
instead of
Old   November 10, 2015, 16:28
same problem :/
Hmm.. can you try
instead of
Old   November 10, 2015, 16:31
Mikko
Can you share your data?
Old   November 10, 2015, 16:33
sent you a pm
Old   November 11, 2015, 05:24
Mikko
Resulting script which opens a CSV file, creates grid with Delaunay triangulation, calculates average of a scalar over spherical planes and finally saves the results to a file.
import numpy as np
import paraview.simple as pv
# Path to file
filename = 'data.csv'
# Result arrays
data = []
R = []
area = []
# Build a pipeline
reader = pv.OpenDataFile(filename)
reader.UpdatePipeline()
ttp = pv.TableToPoints(reader, XColumn='x', YColumn='y', ZColumn='z')
delaunay = pv.Delaunay3D(ttp)
calc = pv.Calculator(delaunay, ResultArrayName = 'radius', Function = 'sqrt(coordsX^2+coordsY^2+coordsZ^2)')
contour = pv.Contour(calc,ContourBy = ['POINTS','radius'],Isosurfaces = [0])
int = pv.IntegrateVariables(contour)
for r in np.linspace(0.01,1,100):
   A = ns.vtk_to_numpy(intData.GetCellData().GetArray('Area'))[0]
   data.append(ns.vtk_to_numpy(intData.GetPointData().GetArray('data'))[0]/A)
   area.append(A)
   R.append(r)
np.savetxt('output.txt',zip(data,R,area))
fportela likes this.
Old   November 18, 2015, 05:31
The script works fine for a single slice, but how could I extend it to evaluate an average over all the slices along the axial direction?
Old   November 30, 2015, 02:11
pan
Thomas pan is on a distinguished road
Hi Felipe,
I follow your code to my case,but i get the following error:
Traceback (most recent call last):
File "<string>", line 54, in <module>
File "/usr/lib/python2.7/dist-packages/paraview/numpy_support.py", line 198, in vtk_to_numpy
typ = vtk_array.GetDataType()
AttributeError: 'NoneType' object has no attribute 'GetDataType'
My code is:
import numpy as np
# Result arrays
p0 = []
R = []
# Build a pipeline
slice = pv.GetActiveSource()
calc = pv.Calculator(slice, ResultArrayName = 'radius', Function = 'sqrt(coordsX^2+coordsY^2)')
for span in np.arange(0,1,0.05):
contour.Isosurfaces = [span]
# L = ns.vtk_to_numpy(intData.GetCellData().GetArray('Le ngth'))[0]
L = ns.vtk_to_numpy(intData.GetCellData().GetArray('ra dius'))[0]
p0.append(ns.vtk_to_numpy(intData.GetPointData().G etArray('p'))[0])
R.append(span)
plt.plot(p0,R)
plt.show()
can you tell me what's wrong?Thank you very much!
Thomas pan is offline   Reply With Quote
Old   November 30, 2015, 02:12
pan
Hi Mikko,
My code is:
import numpy as np
# Result arrays
p0 = []
R = []
# Build a pipeline
R.append(span)
plt.plot(p0,R)
plt.show()
Can you tell me what's wrong?Thank you very much!
export data, integral average
combining parabolic inlet velocity profile with time varying velocity vector values jawapasu OpenFOAM 3 July 10, 2023 05:41
serial udf to parallel udf radioss Fluent UDF and Scheme Programming 10 January 19, 2019 08:56
Volume Integral or Surface Integral for velocity saharesobh FLUENT 2 November 20, 2012 03:51
calculate the average velocity of particles robert FLUENT 0 August 1, 2008 09:44
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
