[General] Integral average of velocity values on a slice |
October 5, 2015, 15:56 |
Rep Power: 10 |
I need to evaluate the integral average of velocity values on a slice in ParaView 4.3.1.
I want to obtain a plot of the axial velocity of water as a function of radial position in a cylinder. Is it possible to perform this in ParaView or not? If I need to export the data, how could I automate the process of slice selection along the axial direction? Thank you in advance. |
October 12, 2015, 08:09 |
Mikko
Everything is possible with ParaView However, I'm not sure if I understand your question. If you have a cross section of a pipe and you want to get the average velocity over radial distance try following:
import numpy as np import matplotlib.pyplot as plt from paraview import numpy_support as ns # Result arrays U = [] R = [] # Build a pipeline slice = GetActiveSource() calc = Calculator(slice, ResultArrayName = 'radius', Function = 'sqrt(coordsX^2+coordsY^2)') contour = Contour(calc,ContourBy = ['POINTS','radius'],Isosurfaces = [0]) int = IntegrateVariables(contour) # Loop over different radial distances and save the results for r in np.arange(0.05,0.5,0.05): contour.Isosurfaces = [r] intData = servermanager.Fetch(int) L = ns.vtk_to_numpy(intData.GetCellData().GetArray('Length'))[0] U.append(ns.vtk_to_numpy(intData.GetPointData().GetArray('U'))[0][2]/L) R.append(r) #plot with matplotlib plt.plot(U,R) plt.show() Mikko Last edited by Flowkersma; November 9, 2015 at 05:36. |
November 9, 2015, 17:58 |
#3 | |
Felipe Alves Portela
Hi Mikko,
I've been trying your suggestion below (as you suggested in another thread) but I keep getting a segmentation fault at the "servermanager.Fetch" stage. Any idea why this may be happening? I'm running version 4.3.1 btw Quote:
November 10, 2015, 05:25 |
Mikko
Hi Felipe,
I haven't encountered segmentation fault there. Have you succeeded to fetch data before? Have you checked your RAM consumption? Can you share your script? |
November 10, 2015, 05:36 |
Well, tbh this is my first go at using python scripts in ParaView so I guess I have never succeeded to fetch data before x)
I load a .csv file and convert it to points using the TableToPoints filter, then I generate a volume by using the Delaunay3D filter, then I want to compute the integral over several surfaces (which seems to work when I manually generate the contours) As for the memory, nothing weird seems to happen... I tried both on a mac and a linux machine and the same thing happens on both! The script I used for the integration is this (adapted from the one you posted): Code:
import numpy as np from paraview import numpy_support as ns import paraview as pv import paraview.simple as ps # Result arrays U = [] R = [] # Build a pipeline slice = ps.GetActiveSource() calc = ps.Calculator(slice, ResultArrayName = 'radius', Function = 'sqrt(coordsX^2+coordsY^2+coordsZ^2)') contour = ps.Contour(calc,ContourBy = ['POINTS','radius'],Isosurfaces = [0]) int = ps.IntegrateVariables(contour) # Loop over different radial distances and save the results for r in np.arange(0.1,1.5,0.1): contour.Isosurfaces = [r] intData = pv.servermanager.Fetch(int) L = ns.vtk_to_numpy(intData.GetCellData().GetArray('Length'))[0] U.append(ns.vtk_to_numpy(intData.GetPointData().GetArray('U'))[0][2]/L) R.append(r) |
November 10, 2015, 16:27 |
#6 | ||
Mikko
Hmm.. can you try
November 10, 2015, 16:28 |
November 10, 2015, 16:31 |
Mikko
Can you share your data?
November 10, 2015, 16:33 |
November 11, 2015, 05:24 |
Mikko
Resulting script which opens a CSV file, creates grid with Delaunay triangulation, calculates average of a scalar over spherical planes and finally saves the results to a file.
import numpy as np from paraview import numpy_support as ns import paraview.simple as pv # Path to file filename = 'data.csv' # Result arrays data = [] R = [] area = [] # Build a pipeline reader = pv.OpenDataFile(filename) reader.UpdatePipeline() ttp = pv.TableToPoints(reader, XColumn='x', YColumn='y', ZColumn='z') delaunay = pv.Delaunay3D(ttp) calc = pv.Calculator(delaunay, ResultArrayName = 'radius', Function = 'sqrt(coordsX^2+coordsY^2+coordsZ^2)') contour = pv.Contour(calc,ContourBy = ['POINTS','radius'],Isosurfaces = [0]) int = pv.IntegrateVariables(contour) # Loop over different radial distances and save the results for r in np.linspace(0.01,1,100): contour.Isosurfaces = [r] intData = pv.servermanager.Fetch(int) A = ns.vtk_to_numpy(intData.GetCellData().GetArray('Area'))[0] data.append(ns.vtk_to_numpy(intData.GetPointData().GetArray('data'))[0]/A) area.append(A) R.append(r) np.savetxt('output.txt',zip(data,R,area)) |
November 30, 2015, 02:11 |
#11 | ||
pan
Rep Power: 11 |
Hi Felipe,
I follow your code to my case,but i get the following error: Quote:
November 30, 2015, 02:12 |
#12 | ||
pan
Rep Power: 11 |
Hi Mikko,
November 18, 2015, 05:31 |
#13 |
Rep Power: 10 |
The script works fine for a single slice, but how could I extend it to evaluate an average over all the slices along the axial direction?
export data, integral average |
combining parabolic inlet velocity profile with time varying velocity vector values | jawapasu | OpenFOAM | 3 | July 10, 2023 05:41 |
serial udf to parallel udf | radioss | Fluent UDF and Scheme Programming | 10 | January 19, 2019 08:56 |
Volume Integral or Surface Integral for velocity | saharesobh | FLUENT | 2 | November 20, 2012 03:51 |
calculate the average velocity of particles | robert | FLUENT | 0 | August 1, 2008 09:44 |
