[General] Paraview parallel processing with pvbatch
Like Tree1Likes
  • 1 Post By wouterremmerie
Old   January 29, 2018, 08:51
Default Paraview parallel processing with pvbatch
Wouter
wouterremmerie is on a distinguished road
Hello all,
we've found numerous posts on how to run paraview in parallel, but somehow we are still stuck.
We have python scripts that open OpenFOAM data and process it into expored x3d files. It works fine with pvpython. Paraview was installed with the MPI option enabled.
If we then switch to pvbatch and run this command:
mpirun -np 4 pvbatch script.py -parallel
it runs 4 parallel processes but no speed ups are noticeable, and we get the following error (just after startup):
[[12489,1],0]: A high-performance Open MPI point-to-point messaging module
was unable to find any relevant network interfaces:
Module: OpenFabrics (openib)
Host: ip-172-31-29-146
Another transport will be used instead, although this may result in
lower performance.
[ip-172-31-29-146:27841] 3 more processes have sent help message help-mpi-btl-base.txt / btl:no-nics
[ip-172-31-29-146:27841] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
It seems as if the same process is started 4 times instead of splitting it up in 4 smaller parts (which would match earlier reportings on this forum).
If we then execute the following (based on other posts)
mpiexec -np 4 -mca btl pvbatch script.py -parallel
no output x3d files are generated and we get the following error 4 times (once for each process we assume):
Error: Could not import vtkCommonComputationalGeometry
Traceback (most recent call last):
File "/home/ubuntu/ParaViewBuild/lib/site-packages/paraview/vtk/vtkCommonCore.py", line 5, in <module>
from .vtkCommonCorePython import *
ImportError: No module named 'paraview.vtk.vtkCommonCorePython'
During handling of the above exception, another exception occurred:
File "/home/airshaper/progress/runFiles/primalRun/MakeStreams3D.py", line 6, in <module>
from paraview.simple import *
File "/home/ubuntu/ParaViewBuild/lib/site-packages/paraview/simple.py", line 43, in <module>
from paraview import servermanager
File "/home/ubuntu/ParaViewBuild/lib/site-packages/paraview/servermanager.py", line 53, in <module>
from paraview import vtk
File "/home/ubuntu/ParaViewBuild/lib/site-packages/paraview/vtk/__init__.py", line 7, in <module>
from paraview.vtk.vtkCommonCore import *
File "/home/ubuntu/ParaViewBuild/lib/site-packages/paraview/vtk/vtkCommonCore.py", line 9, in <module>
from vtkCommonCorePython import *
ImportError: No module named 'vtkCommonCorePython'
Our goal is to run this script in parallel using pvbatch.
Does anyone have any clue to what we are doing wrong?
Thanks!
Wouter.
wouterremmerie is offline   Reply With Quote
Old   February 20, 2020, 03:16
venu
Venu Angirekula is on a distinguished road
Hey Wouter,
Did you get answer for this type of problem. If so, kindly share how to run paraview in parallel using Local computer.
Venu Angirekula is offline   Reply With Quote
Old   February 26, 2020, 10:41
Default Paraview in parallel
Wouter
no we didn't find a solution:
it seemed like none of the functions were actually running in parallel.
We did manage to launch multiple processes, but it didn't speed up - it seemed to just run the same process in full on each processor.
But I don't think this is a final conclusion, perhaps we should give it another look but unfortunately, no answer for now...
Venu Angirekula likes this.
Parallel processing of OpenFOAM cases on multicore processor??? g.akbari OpenFOAM Running, Solving & CFD 31 November 1, 2017 09:25
Star-CD with ParaView usker STAR-CD 3 December 9, 2015 14:20
problem for parallel processing minaret OpenFOAM Running, Solving & CFD 14 January 19, 2015 23:41
Fluent 15.0 Parallel and Batch Processing on a Supercomputer n_bowen FLUENT 0 August 26, 2014 13:46
Grid Check Fails in Parallel Processing Mode askance Main CFD Forum 0 October 20, 2010 10:11
