[General] EnSight Binary vs ASCII Format Erroneous Negative Values
Old   June 25, 2019, 15:32
Default EnSight Binary vs ASCII Format Erroneous Negative Values
Justin Weinmeister
jrweinmeister is on a distinguished road
Has anyone come across an error when importing Fluent data into Paraview using the Ensight format in getting incorrect values? In my case I get negative values of an all positive variable (the absolute value of the u'v' Reynolds stress) when using the Ensight binary format in Fluent. When using the ASCII format, I get the appropriate values. The ASCII values appear as: AsciiData.jpg
where the binary data gives the following results when the negative values are removed: BinaryThreshold.jpg
This behavior is consistent for either node or cell centered value exports and exists in the imported values itself, not just the slices. I am unsure which program is causing the issue, but I would like to narrow down the problem if possible.
I posted the same issue on the Paraview forum here: https://discourse.paraview.org/t/ens...ve-values/2107
jrweinmeister is offline   Reply With Quote
ensight, fluent, paraview
Positive or negative values of Lambda2 for vortex structure visualization? vidyadhar OpenFOAM Running, Solving & CFD 3 November 27, 2019 08:03
save to variable filename inside loop FrankR Fluent UDF and Scheme Programming 5 January 30, 2019 11:16
[Commercial meshers] covert binary .msh file to ascii .msh file shivani17 OpenFOAM Meshing & Mesh Conversion 0 October 25, 2018 00:59
VAWT Sliding Mesh - Negative Torque Pervispasco OpenFOAM Running, Solving & CFD 0 August 5, 2018 09:59
Sliding mesh error Karl Kevala FLUENT 4 February 21, 2001 15:52
