[General] Paraview collapses when I try to import Fluent .case
Like Tree1Likes
  • 1 Post By luisvolumentres
Old   May 25, 2022, 03:28
Unhappy Paraview collapses when I try to import Fluent .case
Luis
luisvolumentres is on a distinguished road
Hi, everyone!
I’m trying to post process my Fluent simulation (75 m poly-hex core mesh) into Paraview. Therefore, I have exported my data in Ensight Gold format. After that, I have changed manually the .encas file into .case file. I have done the same proccedure with smaller mesh problems (e.g. 10 M cells) and I have not experienced any problem. I thought about a RAM problem but since my computer has around 700 GB RAM and during the opening trial it does not reach the maximum capacity, I guess it is not the problem. Has anyone any thought about what could lead to this problem? Btw, I’m using Paraview 5.10 and Fluent 2020 R1. Thank you so much in advance!!
Best regards,
Luis
luisvolumentres is offline   Reply With Quote
Old   May 26, 2022, 11:12
Default Problem Solved
Luis
I found a solution for the issue. I exported the results data in Ensight enabling Ensight Parallel. Then, I loaded all the .case for all the partitions into Paraview and afterwards, I merge all the data files into a datagroup within Paraview.
Best regards,
Luis
CarlosRom90 likes this.
fluent, paraview
import chemkin mechanism into fluent motaz.medhat FLUENT 8 July 20, 2023 17:21
Post-Processing using Paraview with Fluent Data KelvinTan FLUENT 1 June 19, 2023 05:36
Fluent -> ParaView Newbie FLUENT 23 September 17, 2021 02:57
Export Particle Data From Fluent to Paraview liliana FLUENT 2 November 18, 2016 09:14
Import Soliworks geometry to Ansys Fluent 12.0 nunolopes FLUENT 0 October 7, 2010 11:24
