[OpenFOAM] Plotting Cell-Center Data Over Line |
June 29, 2023, 09:09 |
Josh
Rep Power: 3 |
I appreciate that this problem has been raised before (mainly here: Plot over line question) but I am having trouble implementing the suggested solutions. I would like to use a tool akin to the "Plot Over Line" feature to save some CFD data from a 2D mesh. The problem is that the Plot Over Line feature is incapable of using solely the data produced by the CFD code and stored at the cell centres. Instead, it uses some interpolation which reduces the precision of the data I would like to analyse quite considerably. Ideally, the solution would compute line segments within each of the cells in the mesh and then associate a cell-centered value with them and plot only the data at those cell-centres. Is there a straight-forward way of doing this in Paraview? All suggestions are welcome. Thanks in advance, Josh |
December 13, 2023, 12:20 |
CFD_Lovers
Rep Power: 11 |
Hello Josh,
I am having the same problem. Did you find any solutions? Sina |
December 13, 2023, 12:23 |
#3 | |
Josh
Rep Power: 3 |
Hi Sina, Yes, there is a solution to this. It turns out that Paraview is not an optimal software for extracting the cell-centred data which is produced by an OpenFOAM solver. To obtain this data, you should use the sampleDict with the interpolation method set to "cell", and you can extract data along lines this way. Note that this is actually built-in functionality with the standard OpenFOAM installation, so I found in my cases that this was an easier way to deal with the data I wanted to use than going through Paraview. Hope this helps. Josh |
December 13, 2023, 13:01 |
CFD_Lovers
Rep Power: 11 |
Hello Josh,
Thank you for your prompt answer. Yes, the plot over line feature is the key answer. However, if you look at "sampleDict", you notice you can manage the number of points (nPoints) so that the solver interpolates data in whatever number of points along the desired line. My question is, how can I make sure that the very first data is exactly at the very first cell above the wall, for instance? Imagine you would put the lowest point of your line on the edge of your domain. I would expect openFOAM to "extrapolate" data from the real very first cell centre (that has a values) to the desired point I asked for, which is in this example lower than the cell centre. It might be addressed with some options like "lineUniform", "libeCell", .. in sampleDict, which I am not sure yet. Sina |
December 14, 2023, 06:51 |
#5 | |
Josh
Rep Power: 3 |
In order to do this, you should use the lineCell type. This option does not require that you specify the number of interpolated points; rather, you will specify the start and end points of your line and, if you have the interpolationScheme set to "cell", it will indiscriminately extract the cell centres. Example: sets ( Example { type lineCell; axis x; start ( 0 0 0); end ( 2 0 0 ); } ) Otherwise, if you refer to a point which lies on a boundary which is not appearing, I think it's probably possible in most cases to determine "by hand" the value of the cell. Hope this helps... Josh |
January 28, 2024, 10:04 |
Nafiz Ahmed Khan
Rep Power: 2 |
Hello Josh,
I'm trying to extract cell-centered U and V component velocities (U_x and U_y) from the entire specified zone I marked in the attached picture. Is there any way to extract those values either in ParaView or SampleDict, as you mentioned earlier? vel_mag.jpg Regards, Nafiz |
line |
[Commercial meshers] Problem with Mesh conversion from FLUENT Meshing to OpenFOAM | mn17jyf | OpenFOAM Meshing & Mesh Conversion | 3 | November 1, 2023 09:49 |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 07:31 |
[blockMesh] BlockMeshmergePatchPairs polyTopoChanger | benru | OpenFOAM Meshing & Mesh Conversion | 3 | June 29, 2008 21:24 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
