[OpenFOAM] Printing text in paraFoam
Old   September 3, 2007, 11:02
Default Printing text in paraFoam
Christian Lindbäck
christian is on a distinguished road
How can I, in paraFoam, print text in the current window at an arbitrary position? This is to explain what is plotted.
Best regards,
Christian Svensson
christian is offline   Reply With Quote
Old   September 3, 2007, 13:54
Default In the right side main display
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
In the right side main display window, look around the top left corner. You'll see a button called '3D view'. Click it. Alternately you can select '3D view properties' from the View menu. Now, you should select the 'Annotate' tab from the left frame. In the 'Corner Annotation' section, you can choose to write stuff on all four corners of the display window or just the ones where you want.
Hope that helps.
msrinath80 is offline   Reply With Quote
Old   September 6, 2007, 08:33
Default That I know, what I want to do
Christian Lindbäck
That I know, what I want to do is to print text at an arbitrary position. Is this not possible?
[OpenFOAM] Unable to launch parafoam & boonhow ParaView 5 March 23, 2022 08:09
[OpenFOAM.com] paraFoam cannot open due to Qt issues - [Solved/Information] u2berggeist OpenFOAM Installation 2 July 2, 2018 17:03
Rounding Values in Post stifelistefan CFX 4 March 5, 2014 08:10
[OpenFOAM] How to use paraFoam on a cluster andreas ParaView 1 March 6, 2013 17:11
[OpenFOAM] OpenFoam (Ubuntu): paraFoam via Xming+PuTTY raketenmaid ParaView 4 February 5, 2013 05:20
