[OpenFOAM] Cutting plane
Old   January 24, 2006, 05:24
Default Cutting plane
Anja Stretz
anja is on a distinguished road
I created a cutting plane with the "Filter cut". Now I would like to display only one side (one half) of the geomerty.
Can someone please explain me how to do that?
Or is there any other possibility to see what happens inside a 3D geometry?
Thanks a lot,
Anja
anja is offline   Reply With Quote
Old   January 28, 2006, 17:27
Default Hi Anja, Select original data
Masato Otsuki
otsuki is on a distinguished road
Hi Anja,
Select original dataset and trun off the check
of "data" in display panel.
Other method is to use "clip" filter.
otsuki is offline   Reply With Quote
Old   February 17, 2006, 09:14
Default dear all, Can we get variab
VVqf
vvqf is on a distinguished road
dear all,
Can we get variable profile/data (say, pressure/Velocity profile) through a cutting plane with paraView?
i couldnt found any export functionality in paraView..
Thanks.
vvqf is offline   Reply With Quote
Old   February 23, 2006, 05:07
Default New versions of Paraview have
Mattijs Janssens
New versions of Paraview have the 'Save Data' option (under the right mouse button) which saves the currently selected item to a file.
You'll probably have to use some vtk code to read them in again since they will be xml.
Old   February 23, 2006, 05:49
Default Mattijs, Thanks for the answe
VVqf
Mattijs,
Thanks for the answer!
I am using the 2.2 version.
I just found the 'Save Data' option under menu File, but under right button no such option.
you meant the Latest version(2.4.2)?
http://www.paraview.org/HTML/Download.html
Old   February 23, 2006, 05:54
Default You're right, it probably is o
Mattijs Janssens
You're right, it probably is only on the file menu
Let us know if/how you manage to read that data (back into OpenFOAM)
Old   February 23, 2006, 05:58
Default with the 'Save Data' option un
VVqf
with the 'Save Data' option under menu "File", i can only save file as *.pvd.
not knowing what I could do with *.pvd file ...
Old   February 23, 2006, 07:19
Default ParaView files: This is the de
VVqf
ParaView files: This is the default file format for ParaView. The data set created by this reader may be of any type supported by ParaView (polygonal, uniform rectilinear, nonuniform rectilinear, curvilinear, or unstructured). The file extension is .pvd. This format supports spatially partitioned and multi-block data. ParaView can write data files in this format. There are no modifiable parameters for reading ParaView files unless the file contains multiple time steps.
http://www.paraview.org/Wiki/ParaView:FAQ
let me see, install the newest version, and try to read the the .pvd file
Old   July 4, 2006, 04:43
Default Hello, the cutting plane me
scurtu
the cutting plane menu has the options: plane and sphere.
But I need a cutting cylinder surface.
How can I cut the domain with a cylinder?
Thanks a lot,
Nicoleta
Old   October 31, 2012, 09:20
Avdeev Evgeniy
j-avdeev will become famous soon enough
Send a message via Skype™ to j-avdeev
Let's make all questions about cutting plane in one thread.
So, my question is:
how can I get view after cutting with coarse mesh cells (not plane)?
It have to be like this:
http://img-fotki.yandex.ru/get/6614/...5d9a2ac2_L.jpg
Thank.
j-avdeev is offline   Reply With Quote
[Commercial meshers] faceSet of a cutting plane for a internal patch definition RubenGutiii OpenFOAM Meshing & Mesh Conversion 1 April 17, 2019 05:10
Measure the surface of the faces of a triangulated cutting plane Pagoda OpenFOAM Post-Processing 3 August 20, 2018 09:51
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Curiosity & Question about cutting plane through axisymmetric region aerospain OpenFOAM Post-Processing 0 October 4, 2012 04:05
plane cutting complex geometry in the middle Lilly FLUENT 0 July 27, 2011 09:01
