[OpenFOAM] Region Status Issues
Old   January 28, 2010, 11:51
Default Region Status Issues
stefan
oldschool is on a distinguished road
have just installed OpenFoam without any troubles. Have just tryed out the first tutorial (cavity).
Unfortunately, something doesn't seem to be right with my paraFoam. The Region Status pannel is not where its supposed to be (doesn't exist).
However, it is very important for me to check the boxes in the region status pannel, as I won't e able to see my mesh, shape and so forth.
I have read the tutuorial numerous times and I just can't find what I might have done wrong.
I did following steps:
1) I added the bashrc comand in order to run open foam in my terminal
2)cd $FOAM_RUN/tutorials/incompressible/icoFoam/cavity
3) I have done checkMesh
4) paraFoam (files which are being created through icoFoam area already there for the cavity example. But have also tryed to delete it and run the calculation from the beginnning)
5)paraFoam
It opens up my paraFoam Window, where I can also see the cavity part being which has been loaded.
Got the same issue with all other examples which are supplied with openfoam
Thank you already for your replies and help
oldschool is offline   Reply With Quote
Old   February 4, 2010, 09:50
falcao is on a distinguished road
Perhaps you are using a 64 bit version while your system is 32 biti Linux!
Try to get a 32 bit paraview version in this site
http://www.paraview.org/paraview/res.../software.html
Decompress, enter in the created directory, enter the bin directory and click in paraview icon. Open the cavity0.vtk and proceed normaly
It works for me
falcao is offline   Reply With Quote
Old   February 4, 2010, 10:04
Try to type uname -m in your terminal command.
If the awser is i686, your Linux is a 32 bit version.
Old   May 17, 2010, 08:08
Default alternative solution
Jean-Baptiste Richard
jean-baptiste.richard is on a distinguished road
I have the same problem as "Oldschool" did, and I found other people talking about the same issue, with further enquiries but still no solution: http://www.mail-archive.com/paraview.../msg04705.html
I actualy have the mentioned symptoms, begining with "Not A Number" values in the dataset.
So, I tried the alternative way to use foamToVTK to export the dataset and open it then. This solution isn't as efficient as the "paraFoam" one should be, but seems to work. for further details see (for instance) http://www.openfoamworkshop.org/2009...Processing.pdf
btw, I'm running with openFoam 1.6 and paraview 3.6.1, on a ubuntu 9.10 32bit platform
Hope it can help,
Jean-Baptiste
jean-baptiste.richard is offline   Reply With Quote
region status issues
Maximum number of iterations exceeded chtmultiregionsimpleFoam Moncef OpenFOAM Running, Solving & CFD 28 July 13, 2020 14:26
multiRegion decomposePar should not decompose each region over all processors svenk OpenFOAM Pre-Processing 1 April 11, 2018 05:44
conjugate heat transfer in OpenFOAM skuznet OpenFOAM Running, Solving & CFD 99 March 16, 2017 05:07
Taking too much for run Grimoli OpenFOAM Running, Solving & CFD 5 November 26, 2013 20:07
cfx5post in batch mode on "graphics-less" Linux frankyd CFX 3 April 12, 2011 16:47
