[OpenFOAM] Help in Paraview (F1) gives strange error |
March 3, 2010, 06:43 |
Ganapathy Iyer
Hi folks,
I have done the most difficult parts i.e. Installed OpenFoam and Paraview. Everything is also running fine BUT When I use F1 or click on help for Paraview, I get a strange error /home/dm2/henry/OpenFOAM/................. But this is not my login nor my path for OpenFOAM. How can I rectify this ? |
March 4, 2010, 02:32 |
#2 | |
Mark Olesen
Rep Power: 40 |
However, there are a number of installation issues with paraview (see http://paraview.org/Bug/view.php?id=9998 for some of them). The makeParaView script in the OpenFOAM 3rdParty directory tries to rectify some of them (eg, the env path editing). It could be that it didn't fully succeed, or that there is yet another problem. Be thankful at least that your "paraview" executable seems to be finding the "paraview-real" backend correctly! If you have a good set of nerves and a bit of time (3/4-1 hr), you could try recompiling paraview on your system. The makeParaView script is IMO the best way to go. There are options for enabling/disabling the various config and make stages. Note that the -envpath option, which is needed to replace the absolute path to gcc with the equivalent environment variables (otherwise you'd never be able to build any plugins), will prevent quick rebuilds later. Here's a pointer to a git repo of the latest cvshead http://github.com/Kitware/ParaView This includes a fairly recent version of Takuya's reader and (as of yesterday) the slightly reworked wavefront OBJ reader is now activated. Since this reader version also handles point and line elements, it is a quite useful alternative to javaview for viewing debug mesh information in OpenFOAM: For systems like openSUSE (11.1, 11.2), you'll need to install libQtWebKit-devel before compiling. With any luck the paraview PARAVIEW_INSTALL_DEVELOPMENT cmake parameter will actually work soon! (see http://www.paraview.org/Bug/view.php?id=8712) |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 07:43 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 20:30 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
How to get the max value of the whole field | waynezw0618 | OpenFOAM Running, Solving & CFD | 4 | June 17, 2008 05:07 |
