How to improve the calculation result for the f |
November 18, 2000, 09:41 |
I have a case which presents a hollow cylinder nozzle with two sloping tapping port submerged in the mold. Inlet condition (from the hollow nozzle) is regarded as fixed mass flux. Outlet condition (from the bottom of the mold) is considered as fixed pressure. Because of complex geometry of the nozzle,Fine Grid and PARSOL are used. All condition is simple and I check it many times.But the solution of Flow Field isn't obviously correct. How can I improve the calculation result for the fluid flowing in complex geometry nozzle by other means?
Thank for your kind reply! |
December 8, 2000, 11:28 |
Re: How to improve the calculation result for the
If you are a supportd user, send your Q1 (and any geometry files needed) to support@cham.co.uk. They will see what is happening.
Improve grid | Gernot | FLUENT | 1 | August 5, 2005 09:36 |
How can CFD be used to improve race car? | A Chu | FLUENT | 1 | February 8, 2004 20:21 |
How to improve the accuracy of the CFX? | Miko | CFX | 4 | June 12, 2003 21:24 |
to improve convergence | Mohamed | FLUENT | 0 | May 14, 2003 05:43 |
How to improve y-velocity | ravi | FLUENT | 2 | March 28, 2003 08:01 |
