Water Droplets Evaporation
Old   March 27, 2003, 14:32
Default Water Droplets Evaporation
Javier
Is it possible to model the evaporation of water droplets(fog) in air. (Heat-Mass Transfer).
We are trying to reduce the humidity of air (fog) mixing it with a source of heated air coming from other facility, but we have a short distance to do it.
bye
Javier L.
Old   March 31, 2003, 09:09
Default Re: Water Droplets Evaporation
MICHAEL MALIN
This sort of problem is usually modelled using an Eulerian-Lagrangian approach, which in PHOENICS means using GENTRA for describing the droplet phase.
An alternative is to use the Eulerian-Eulerian approach, i.e. IPSA in PHOENICS, but this approach is restricted to droplets of a single size.
It is also possible to model this process by solving mixture conservation equations and an equation to describe the species mass fraction of water in any form. The local state of the gas-lquid mixture would be determined on the basis of the assumption of saturation of the droplet phase, and immediate adjustment of the droplets to local conditions. The details of this simplified approach would have to be worked out carefully.
Evaporating water droplets dmoroian OpenFOAM Running, Solving & CFD 0 February 4, 2009 05:26
Evaporation of droplets in cooling tower @cfx10-11 Mauricio Labarca CFX 0 March 28, 2008 20:02
water droplets - help rns CFX 2 March 19, 2008 05:02
Droplets evaporation/combustion Julie Polyakh Siemens 1 May 20, 2002 04:09
Evaporation of droplets in atmosphere A. Rajani Kumar Main CFD Forum 2 January 9, 2001 22:22
