link multi blocs
Old   June 29, 2005, 05:38
Default link multi blocs
ben souissi
My problem is how to turn off a rotor of a pump composed with a fixed number of blades around a diffuser witch is fix in an absolute coordinates system. The method I use is a multiblocs geometry with BFC grids. So my question is how to link each bloc to other blocs after I have defined each one with BFC grids. Can you send me an easy example to train with it. Thank you.
Old   August 4, 2005, 18:02
Default Re: link multi blocs
Mick
Try \phoenics\d_polis\d_enc\MBGRIDS.HTM as a first step.
Also check out the library cases.
would like to get a link to a C program vishal FLUENT 1 February 28, 2008 08:56
link mesh Ana Raquel Rosado FLUENT 7 November 20, 2006 07:09
This is an interesting Link Ahmed Main CFD Forum 0 November 19, 2006 03:05
Faces link Pamela FLUENT 1 February 6, 2006 08:54
Link Alex CFX 0 May 19, 2005 19:20
