Home > Forums > Mesh Generation & Pre-Processing Software > Pointwise & Gridgen
Creating A Constant Pitch Helical Line In Gridgen
Old   July 31, 2007, 00:13
Default Creating A Constant Pitch Helical Line In Gridgen
John Hinkey
I'm trying to create a constant pitch helical line on the surface of a database cylinder using Gridgen. I've tried several ways of doing this, but none of them give a true constant pitch helix - close, but not close enough for griding. Anyone out there have any experience doing this type of thing in Gridgen?
Thanks - John
Old   August 4, 2007, 13:58
Default Re: Creating A Constant Pitch Helical Line In Grid
John Chawner
John,
One way to do this is as follows. All the steps can be done in a Glyph script or you can just generate the points in the script and do the rest interactively.
1. Using a Glyph script, compute points on the helix using the standard analytical definition of the helix (e.g. Wikipedia). Either create a db line from these points or export them to a segment file. Use a large number of points.
2. Create a 360 degree surface of revolution of the desired radius and length.
3. Use cylindrical projection (from the cylinder's axis) to project the helix onto the cylinder.
There also is probably a way to do this analytically. That is, create a surface of revolution and then create a line directly on the surface by computing the points on the helix in the surface's (u,v) space.
Hope this helps. If not, please contact our Tech Support at support@pointwise.com.
Old   August 5, 2007, 00:01
John Hinkey
Thanks John -
Your good folks at Pointwise have already found some work-arounds for me. If anybody wants the details of these let me know.
- John
errors Fahad Main CFD Forum 0 March 23, 2004 13:20
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
creating line for dispalying data ? siswara dana FLUENT 6 September 3, 2001 04:41
