Home > Forums > Mesh Generation & Pre-Processing Software > Pointwise & Gridgen
Confusions about orientation in Pointwise
Old   March 14, 2016, 01:11
Default Confusions about orientation in Pointwise
Xiaosong
Xiaosong is on a distinguished road
I am doing a 2d rae2822 computation with SU2, using mesh from Pointwise. Here, I have three questions:
1. Do we need to check the orientation every time after generating mesh?
2. I should get the same, at least very similar, computational results from several small domains owning the same right-hand-rule orientations, and one big combined domain following the right-hand-rule, correct?
3. I just realized that, in my case, when all the domains had right-hand-rule orientation, the computation was diverging. However, when I used the default orientation after generating mesh, it could give me some good results. I do not quite understand this part.
Hope to get some helpful replies from everyone! Thanks a lot!
Xiaosong
Xiaosong is offline   Reply With Quote
mesh generation, orientation, pointwise, right hand rule, su2
Not defined orientation change while running SU2_CFD mdawson25 SU2 4 May 11, 2017 09:52
[Commercial meshers] Pointwise to Foam - cyclic BC points order Pj. OpenFOAM Meshing & Mesh Conversion 5 August 14, 2016 04:47
[Commercial meshers] Native OpenFOAM interface in Pointwise cnsidero OpenFOAM Meshing & Mesh Conversion 41 May 20, 2012 18:30
Native OpenFOAM interface in Pointwise Chris Sideroff Main CFD Forum 0 January 16, 2009 12:37
