Home > Forums > Mesh Generation & Pre-Processing Software > Pointwise & Gridgen
Structured domain with internal holes
Old   March 22, 2019, 12:51
Default Structured domain with internal holes
Alexander
Alexl93 is on a distinguished road
I'm almost completely new to the pointwise software, and I have this problem that should be quite easy to solve.
I want to create a structured domain, that i can later extrude, where the internal six holes, as seen in the picture, is not part of that domain.
If i make a domain selecting all connectors, a square structured domain without holes appear.
Is there a easy solution to this i'm missing?
Thank you!
Alexl93 is offline   Reply With Quote
Old   March 22, 2019, 15:19
Zach Davis
RcktMan77 is on a distinguished road
You can't create a single structured domain to accomplish the topology that you want. You can, however use multiple structured domains to accomplish what you want. Then you can extrude all of these domains at once.
RcktMan77 is offline   Reply With Quote
Old   March 22, 2019, 15:32
Alexander
Thank you for the answer.
I did do this approach earlier, but alot of blocks and boundaries would then be created.
Would you just make an interface BC between the blocks, or is there another way to deal with this problem?
Old   March 22, 2019, 16:44
Zach Davis
The interface BCs in Pointwise are already created. To demonstrate this, if you go to the CAE menu, and select Set BCs... option, you should see that all the interfaces have already been applied, and all that is left to set are those boundaries which are free.
domain, mesh, structured
How to mesh a domain around a rounded geometry with structured grid quarkz Pointwise & Gridgen 2 March 5, 2019 22:05
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation volleyHC CFX 5 April 3, 2016 05:41
Floating point exception: Zero divide liladhar CFX 11 December 16, 2013 04:07
Named selection for internal surfaces in the domain Ahmed Saeed CFX 1 November 20, 2013 09:32
[ICEM] Structured mesh for a combustor - dilution holes issue Andrea1984 ANSYS Meshing & Geometry 0 October 28, 2013 09:20
