November 16, 2011, 08:13 |
Mesh for a tube with a deflector - Pointwise
salvatore
Hi All,
I am trying to create my CFD mesh using Pointwise. I want to see how a deflector change the flow in a tube (please see attached picture). The problem is that Pointwise create the mesh for the tube and the deflector but when I try to export both mesh, the software does not export the mesh of the surface deflector. Specifically, it seems not possible to create a block that considers the deflector. Do you have any suggestion to create the mesh for this model Many thanks |
November 20, 2011, 14:14 |
John Chawner
Rep Power: 18 |
Hello Salvatore:
I can assure you that Pointwise can generate a mesh such as the one you describe. However, the specifics of the issue you raise can't be diagnosed without knowing what type of grid you've generated (structured hex, tet, hybrid) and how you're exporting it. My suggestion is that you contact our technical support engineers at support@pointwise.com. Best Regards
John Chawner / jrc@pointwise.com / www.pointwise.com Blog: http://blog.pointwise.com/ on Twitter: @jchawner |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
[snappyHexMesh] non-smooth mesh | Svensson | OpenFOAM Meshing & Mesh Conversion | 11 | January 18, 2012 09:13 |
engrid -> save as .stl with boundarie codes | Zymon | enGrid | 31 | August 29, 2011 13:40 |
