Home > Forums > Software User Forums > REEF3D
Problem with X13
Like Tree1Likes
  • 1 Post By TobiasMartin
Old   June 19, 2021, 23:15
Post Problem with X13
siyu
Allison is on a distinguished road
Hello
I am trying to analyze floating body using reef3d.
I’m confused about X13 Rigid body dynamics representation, What's the difference between X13 1 and X13 2? I find that the Ze(X13 1,REEF3D_6DOF_E_force.dat) is not the same as the Fz (X13 2,REEF3D_6DOF_forces_0.dat), I mean they're all resultant force in z direction of the object. So what's the difference between these two options?
With best regards
Allison
Allison is offline   Reply With Quote
Old   June 22, 2021, 04:55
Arun Kamath
kamath is on a distinguished road
As described in the User Guide,
X 13 1 follows the older implementation for the handling of fluid-floating body interface in REEF3D (Bihs and Kamath, 2017, IJNMF 83 (12), 905-916, doi: 10.1002/fld.4333) using the Ghost cell immersed boundary method.
X 13 2 is the new implementation for the same, using a direct forcing ghost cell method, following Martin et al. 2021, Appl. Oce. Res. 106, doi: 10.1016/j.apor.2020.102410.
Arun
X years with REEF3D
kamath is offline   Reply With Quote
Old   June 22, 2021, 22:05
siyu
Thank you so much , I have read two articles, and I ' m confused about "a direct forcing ghost cell method” following Martin et al. 2021, Appl. Oce. Res. 106. I find in the article, it uses the direct force to deal with fluid-structure interaction, where does the "ghost cell" idea reflect?
With best regards
Allison
Old   August 9, 2021, 05:06
TobiasMartin is on a distinguished road
as my colleague has already tried to explain, these are two different implementations.
The ghost cell immersed boundary method is described in Bihs and Kamath, 2017, IJNMF 83 (12), 905-916, doi: 10.1002/fld.4333.
It is though recommended to use X 13 2 which is the continuous direct forcing method following Martin et al. 2021, Appl. Oce. Res. 106, doi:10.1016/j.apor.2020.102410. Here, no ghost cells are required.
I hope this helps.
Kind regards,
Tobias
Allison likes this.
TobiasMartin is offline   Reply With Quote
Old   August 22, 2021, 08:23
siyu
Thank you so much ,Now I have a general understanding that these are two different approaches, I used to confused the description about "a direct forcing ghost cell method"
Now I'm trying to learn more about this method
With best regards
Allison
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 04:37
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
