July 22, 2021, 09:45 |
Generate Focused Wave
Rouxiao Chen
Rep Power: 4 |
Dear Sir,
I want to generate focused wave, and I involved B81, B82, B85, B86, B89,B92, B93 in ctrl.txt, but the error that missing input parameter in ctrl.txt appeared. The case can be succussfully done when I removed B81 but the wave maker did not produce focused wave. How should I do for generating focused wave? The B92 is used to generate theoritical focused wave rather than numerical focused wave, right? Best wishes, Last edited by Freya; July 25, 2021 at 09:30. |
July 26, 2021, 03:14 |
Arun Kamath
Hi Freya,
B 92 is used the select the type of wave theory you want to use as the basis for the focused wave generation. Eg. B 92 41 will use the 1st order focused wave theory Further B 81 is used to provide the x- y- and time locations for the wave focusing B 82 the type of focus amplitude B 85 the spectrum B 86 the number of components B 87 the range of angular frequencies involved Since you want to run a 2D case, the focus location along the y-axis is 0.0 Changing B 81 to 0.0 0.0 19.0 will generate a focused wave at x=0, y=0 at t=19 s in your case. You receive a missing input parameter as B 81 expects three input values and you provide only two. Hope that helps
Arun X years with REEF3D |
July 26, 2021, 17:03 |
Rouxiao Chen
Rep Power: 4 |
Hi, Dr. Kamath
I have modified my file according to your suggestions. I set focusing location at x=0, y=0, and the focusing time at t=0. However, I got strange focused wave when I plot water surface profile at the focusing location. The maximum amplitude is much smaller than I input by B93 which is 0.05. Furthermore, the output wave frequency is higher than theoretical solution based on same input properties. Actually, I don't know how to design the focusing time on REEF:CFD because initial time always start from 0 rather than negative time. Is there any principle to design the focusing time or the focusing time is randomly set? The profile has noises, is there any line to smooth it or the finer mesh should be used to smooth it? Best Wishes, |
July 27, 2021, 03:39 |
Arun Kamath
I would advice not to focus at x=0 y=0 t=0.
July 27, 2021, 07:40 |
Rouxiao Chen
Rep Power: 4 |
Hi, Dr. Kamath,
I got very small wave amplitude, even the biggest wave amplitude is almost zero, but I input this parameter at 0.05 in B93. I don't know what went wrong. Did I input a wrong line? Best Wishes, |
July 27, 2021, 08:25 |
Arun Kamath
I am not entirely sure what you mean.
The first input to B 93 is the wave height or in your case the focused wave height. Set the focus location somewhere towards the middle of the wave tank so that the components have sufficient distance to propagate and focus. Also provide some adequate time for this to occur. Pick the times and locations from an experiment, eg. Ning et al. (doi.org/10.1016/j.oceaneng.2009.07.011) or Bihs et al. (doi.org/10.1115/1.4036206)
July 27, 2021, 08:27 |
Arun Kamath
Also wrt your grid, while REEF3D supports it, I am not really a fan of using -ve coordinates, so wont go into details there.
But most important- your focus location for the central grid (I hope you have changed it after choosing a new focus location) and the focus parameter- 0.05 will barely stretch the grid. Use a ratio closer to 1.
July 29, 2021, 17:42 |
Rouxiao Chen
Rep Power: 4 |
I followed your suggestions and input wave height 0.1 into B93, but I still got very small water surface elevations and failed to got focused wave shown as below image. The water surface elevation before 35s is smaller than that after 35s. Best Wishes, |
July 30, 2021, 08:59 |
Hans Bihs
Hi Rouxiao Chen,
right now your water depth for the wave theory is 0. Either set B 94 to 1.25 or change the reference frame of your setup, so that the bed is at z=0. The same for the x-coordinate: best to start the tank at 0, as this is the origin for X_f, the focusing location. Also, you need to turn on iowave by specifying B 90 1. Another thing: for the given wave, the mesh is overly fine. You will obtain good result with much coarser grids. |
August 8, 2021, 10:37 |
Rouxiao Chen
Rep Power: 4 |
I sucessfully generated focused wave, but the water surface elevation doesn't has good agreement with theoretical solution. I simulated a very nonlinear case which the wave height is 0.3m and the ouput maximum crest should much higher than 2nd-order theoretical solution. I've search the largest eta over all x location and plot water surface elevation over time at that location, but the peak is smaller than the theoretical solution(shown as below figure). Does this result make sense for REEF3D:CFD? Since 2nd-order input results in spend much more time to simulation than linear input does and the results will not change much, I used B92 41 for first estimation. Also, refine mesh is a weakly improvement in this case. |
August 18, 2021, 04:26 |
#11 |
Weizhi
Rep Power: 11 |
Hi Freya,
Good to see your progress. However, I'd like to suggest some changes in your control files for possible improvement of the simulations. 1) Since you are running a 2D simulation, it is good to keep the y-dimension of your numerical wave tank one cell size in control.txt: B 10 0 30 0.0 0.025 0 1.55, since your cell size is 0.025 m. 2) The vertical refinement is better kept uniform around the free surface, the mismatch of the focused crest can be a result of low resolution above water level. Meanwhile, try different stretching factors, for example: B 126 42 1.05 1.5 40 1.25 1.0 4 1.55 1.5, between 1.05 and 1.45 I used a uniform stretching with a factor of 1.0. 3) F 42 command in ctrl.txt should cover the height of the numerical wave tank, in your case should be 1.55 instead of 1.0. F 42 > F60 in most cases: the height of NWT is higher than water level. 4) I see that you didn't have wave gauges for time series, I suppose you used other post-processing tools to extract the time series from VTU files, which is subject to smoothing. I recommend to use REEF3D wave gauge command P 51 15.0 0.0125 in ctrl.txt for obtaining time series. 5) If the result is still not satisfactory after the above changes, you can try to use B 98 3 Dirichlet boundary condition for the wave generation, it might help to preserve the nonlinearity of your input wave. Try the suggestions and let us know how it works out, I hope they help, good luck! __________________ Weizhi Team REEF3D www.reef3d.com |
focused wave |
how to generate a linear wave in flow-3d | mahdypars | FLOW-3D | 7 | August 13, 2021 16:24 |
[waves2Foam] External source file to generate wave motion | mdelisle | OpenFOAM Community Contributions | 4 | December 19, 2019 18:36 |
interFoam wave propagation and explosion of Courant number and residuals | ChiaraViola | OpenFOAM Running, Solving & CFD | 1 | June 26, 2019 05:36 |
Generate a single wave that will dissipate as it travels | monjinz | CFX | 1 | February 24, 2017 05:45 |
generate linear wave in fluent | happyqj | FLUENT | 1 | March 18, 2012 04:25 |
