September 22, 2021, 06:31 |
Run error
Wenyu Zhao
Rep Power: 5 |
Hello, I set a working condition with a fixed time step, but the following contents are always displayed during operation{‘EMERGENCY STOP -- velocities exceeding critical value N 61’}. Then set the value of n61 large enough,, but the above situation still occurs. How should I adjust it?
September 22, 2021, 08:21 |
Arun Kamath
When you encounter an error due to "velocities exceeding N 61", it means that something is wrong with your simulation, resulting in unphysical high velocity values.
You need to inspect what is happening to your simulation, say, in Paraview. Since you use a constant time step, I believe this is the source of your problem. See if the problems goes away when you use the CFL criterion instead. And then, if you really wish to use a constant time step, use the time step that is of the order of that seen in the simulation with the CFL-based time step.
Arun X years with REEF3D |
September 22, 2021, 20:25 |
#3 | |
Wenyu Zhao
Rep Power: 5 |
Pressure outlet boundary condition | rolando | OpenFOAM Running, Solving & CFD | 62 | September 18, 2017 06:45 |
error compiling modified applications | yvyan | OpenFOAM Programming & Development | 21 | March 1, 2016 04:53 |
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x | Saxwax | OpenFOAM Installation | 25 | November 29, 2013 05:34 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 09:30 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 17:38 |
