Home > Forums > Software User Forums > REEF3D
velocities exceeding critical value N 61
Old   April 20, 2022, 10:19
Default velocities exceeding critical value N 61
shuqichang
changshuqi is on a distinguished road
I always get an error at run time that is faster than N 61. I also tried to change some of the parameters, but nothing worked out. I hope you can help me solve it. Attached are my running file and STL file. Thank you for your help .
changshuqi is offline   Reply With Quote
Old   April 22, 2022, 08:44
Arun Kamath
kamath is on a distinguished road
Some comments:
You are attempting a 3D simulation with 2D boundary conditions.
control.txt should have C12 and C 13 as 21 C 14 also 21.
ctrl.txt
I 12 1
N 40 3
N 47 0.1
Have you tried refining the grid, say to dx=0.5m?
Arun
X years with REEF3D
kamath is offline   Reply With Quote
Old   April 22, 2022, 09:06
shuqichang
Originally Posted by kamath View Post
Some comments:
ctrl.txt
I 12 1
N 40 3
N 47 0.1
I will make corrections according to your suggestions. But I removed X 24 after I asked the question, and it worked fine without the error of exceeding N 61. I'm not sure if the problem has anything to do with X 24.
Old   April 22, 2022, 10:07
Arun Kamath
That is interesting.
Are you sure then that the X 24 inputs you provide are correct? A wrong input for the moment of inertia can be a problem.
OR
The stl file may have two few triangles for representing the structure. This can be improved using the cad software you used to generate the stl file.
Arun
X years with REEF3D
EMERGENCY STOP -- velocities exceeding critical value N 61 daineythomas REEF3D 2 December 28, 2021 05:52
SFlow - Error! velocities exceeding critical value N 61 paulathikalam REEF3D 3 October 15, 2021 14:13
N61 Emergency stop--velocity exceeding critical value in less 0.01 meter mesh size. pipi REEF3D 12 July 20, 2021 07:46
Drag Force Ratio for Flat Plate Rob Wilk Main CFD Forum 40 May 10, 2020 04:47
Finding Drag Force from Skin Friction Rob Wilk Main CFD Forum 0 May 8, 2020 06:04
