Usersubroutines in DEC: Problems!
Old   November 8, 2000, 10:36
Default Usersubroutines in DEC: Problems!
Ossi Kaario
I have experienced many difficulties when using Usersubroutines in DEC Alpha Server 4100 and STAR v3100. All the errors seem to be related to the DEC/STAR combination: STAR just quits running a case without any error messages sent to the *.run or *.info files.
Has anybody else experienced odd difficulties when using Usersubroutines in DEC ??
Old   November 9, 2000, 04:27
Default Re: Usersubroutines in DEC: Problems!
Steve Amphlett
I have had numerous problems supporting this combination (for WAVE-STAR, which uses user routines), most of which I've reported back to Compaq/CD/Adapco. They've all made useful suggestions, but I still cringe whenever a Compaq WAVE-STAR support question comes in.
Problems I've had include: - MPI version compatibility mismatches - Interactions between compile flags and MPI (-fpe1 switch in starlink causes MPI star to trap underflow, -fpe0 causes star to crash(??)) - Inability to run successfully on our 2-CPU DS20
What screen output do you get if you build and execute star from a shell prompt rather than going through the GUI (e.g. floating point error, segmentation fault)?
- Steve
Old   November 9, 2000, 07:43
Ossi Kaario
When I run with v3100A and try to use subroutine reacfn.f, I got a shell window message saying:'forrtl: error (73): floating divide by zero Abort process'. Fortunately, if I run with v3100B and with the same reacfn.f, the run goes without problems.
Ossi
Old   November 9, 2000, 10:50
Steve Amphlett
Would anyone from CD care to comment on this? Is this a known bug fixed by 3100B?
UDF problems Winnie FLUENT 22 February 29, 2020 04:32
Problems with Fluent on simple 1D problems agg FLUENT 3 November 21, 2008 11:55
MPI PROBLEMS gtg627e OpenFOAM Running, Solving & CFD 20 October 5, 2007 04:02
UDF problems Paolo Lampitella FLUENT 5 September 8, 2005 20:43
Problems with tut 7-3 Bo Jensen Siemens 1 February 25, 2004 17:01
