External flow BC
Old   December 19, 2002, 03:06
Default External flow BC
roadracer
Hi everybody I am simulating a 2D wing profile near a wall. At the bottom side of the domain I have a wall, at the left I have an inlet. Does anybody know what is the best combination of the other boundaries? Wall at the top end outlet at the right or pressure both at the top and at the right? Are there any other combinations? Any help apreciated.
Old   January 7, 2003, 06:27
Default Re: External flow BC
stex
inlet at left outlet at right wall slip up ( or symplane ) front and rear of you put Symplane.
Don't use pressure because in this way the process is very slow.
Old   January 8, 2003, 02:40
roadracer
OK, thank you. Why not use an outlet comprising both right and upper side?
Old   January 8, 2003, 06:18
Joern Beilke
There was a long discussion about this under
http://www.cfd-online.com/Forum/main....cgi?read=2289
Why Re is different for external and internal flow john CFX 3 June 13, 2007 22:31
external flow Phil FLUENT 2 November 24, 2002 01:21
External flow aerodynamic Sulaiman akhlaken Siemens 0 September 5, 2002 02:54
External flow Tadiwos CFX 2 August 28, 2001 03:07
External Flow-compressible flow solver-lift/drag Tom Brown Main CFD Forum 7 December 29, 2000 13:41
