boiling and evaporation examples
Old   March 27, 2003, 05:38
Default boiling and evaporation examples
Drummer
Does anyone have examples of user subroutines, realizing evaporation and boiling of droplets???
Thanks
Old   March 27, 2003, 21:07
Default Re: boiling and evaporation examples
cjtune
I think STAR-CD already has heat/mass transfer and boiling models for droplets, covering both cases when the droplet either evaporates instantaneously or loses its mass gradually.
You can read about it in the methodology manual at pg.12-12... unless you have something special in mind.
Old   March 28, 2003, 02:08
Drummer
the problem is that when I use standart models, droplets do not evaporate - after temperature 373K they continue get hotter, while the temperature must be constant whu\ile they evaporate...
Old   March 28, 2003, 04:05
cjtune
I think you might have set-up the droplet properties wrongly somewhere. Also, the STAR-CD methodology manual do mention that STAR-CD takes account of such things (note that the T of the droplet can be greater than T for boiling, eg. when the ambient P is higher than atm). BTW, the temperature must be constant only if the droplet's boiling (latent heat process). Evaporation can happen at any temperature that a droplet is in liquid phase, below T boiling.
water boiling, evaporation, condensation Hao FLUENT 14 April 21, 2017 13:08
How to simulate boiling/evaporation? Effendi Ali FLUENT 1 December 12, 2003 04:38
Need UDF examples ! Riham FLUENT 3 May 9, 2003 21:52
Examples Martin Siemens 1 March 26, 2003 14:51
need pdf examples olivier FLUENT 1 May 18, 2001 09:48
