March 3, 2004, 11:32 |
.run file
hi,
how can you set the '.run' file to give you the passive scalar (concentration) values. Every time I run my model the .run file has a field for all the passive scalars I've defined but every itteration it assign them '0' values (well 0.000000e00, something like that), but this is not true, when I plot them everyone has a different value in every cell. My guess is that it may be linked with the way I define the scalars, for example to define 'x' passive scalar I would use:'sc,#,defi,passive,ufef $X $sc,#,off'. This is how the star guide tells us to define them, but you dont get any information out of them at the .run file. Is there something you need to define to obtain this values at the run file, or is it nessesary to create your own information file for your passive scalars? kind regards, isidro |
PLOT3D ASCII solution file to MATLAB data file | Sandeep Rana | Main CFD Forum | 4 | June 11, 2010 09:48 |
[OpenFOAM] ParaView exiting while trying to save image file or movie file | 21kalee | ParaView | 3 | January 23, 2008 16:01 |
Changing gambit file without change of case file?? | Asghari | FLUENT | 2 | August 28, 2006 13:48 |
Covert gambit file to polyflow file | John | FLUENT | 5 | August 6, 2004 08:31 |
Converting a surface file to a volume file | Amir | FLUENT | 2 | December 30, 2002 04:53 |
