inflow pressure boundary
Old   March 18, 2004, 02:07
Default inflow pressure boundary
natesan
Is it possible to specify a pressure boundary in star cd that permits only inflow into the domain. Please remember that the quantity of inflow is an unknown parameter. Thanks in advance
Old   March 18, 2004, 03:20
Default Re: inflow pressure boundary
Richard
If you know your stagnation pressure rather than you static pressure then you could use a stagnation boundary: this only allows inflow. Otherwise you would have to use a pressure boundary with your known static pressure; the flow will decide for itself whether there is inflow or outflow or both.
Old   March 18, 2004, 12:52
Ashish Joshi
Do you have a compressible flow and pressure boundary used at the 'outlet'? If yes, there is a possibility that you may have recirculation at the pressure boundary, i.e. flow coming in through the outlet boundary. Do read the article on compressible flow on adapco-online.com. It will clear all your doubts. Ashish
Arbitrary inflow boundary condition Munikrishna Nagaram Main CFD Forum 0 February 23, 2009 11:03
Inflow Boundary Condition oevermann OpenFOAM Running, Solving & CFD 0 July 27, 2006 02:56
curved inflow boundary condition Rachna Main CFD Forum 0 June 16, 2006 14:31
Treatment of inflow boundary William M. Main CFD Forum 2 June 1, 2005 02:46
axial flow pump, inflow boundary tma CFX 3 September 26, 2002 15:28
